Hi Herbet, could I please get a Windows 11 driver for the RM520N-GL. I tried the version 2.8 that is available on the Quectel website and it doesn’t work work. The device still shows that no driver was installed in Device Manager. In the past, I got this to work on Windows 11, I believe with an older driver? Maybe 2.3?
Hi, could you also send me the Windows 10 USB Drivers for RM520N-GL ? Thanks !
@silvia can you please help, thanks ![]()
Dear @werty
For windows driver, you can download from website.
Ooh okay, I only found a usb driver: Quectel_Windows_USB_Driver(Q)_NDIS_V2.8_EN
I guess I’m a bit confused, because I thought there would be more drivers than just a usb driver… like for example, what happens if I wanted to connect it to the PC in another way besides usb? (or does windows automatically detect it in that case?)
Dear @werty
In Windows, we only have USB drivers.
How did you contact RM520N with PC?
Hi, do you recommend connecting via usb? Otherwise, I was thinking about using a PCIe adapter (mentioned in my topic here). However, I wasn’t sure if using a PCIe adapter that it would be recognized by windows, of it drivers would also be required.
Dear @werty
You can follow the suggestion from other guys in that topic.
But for Windows, we only have USB driver.
Would it be possible for me to also get the Windows 10 PCIE drivers, latest firmware and at commands for the RM520N-GL?email:mnb35558810@gmail.com
Dear @Timothy_Tian
Did you insert to PC directly or via board?
Please share your current firmware version.
