Can i please get the Quectel_Windows_USB_Driver(Q)_NDIS_V2.3.3 for the RM520N-GL?
Will you also send me the driver package?
Please email me the drivers as well please, For windows
Ive installed it however COM port is still greyed out
I have resent a new to you,pls try again
I am also using the RM520N-GL module with a Korea KT 5G SIM card. After installing the driver, it only shows LTE (and can connect to the internet), but 5G is not displayed.
Could you please send me the driver for the Quectel RM520N-GL that is compatible with Windows 11 (64-bit), along with the latest available firmware? You can send it to panitsasi@gmail.com.
Thank you!
The network standard and the driver should have no direct relationship. You can try to lock the NR network
Would you please send me the driver package for the RM520N-GL for windows 10? The USB drive included with the development kit does not appear to have the correct drivers.
Can you please also send me the drivers? Thanks!
Could you please send me the driver for the Quectel RM520N-GL that is compatible with Windows 11 (64-bit), along with the latest available firmware? You can send it to jin@harbormax.com.
Thank you!
I have sent them to your email,pls check, if your verison is R01,pls use R01 firmware to upgrade
hello , please ca n u telle me how did you do for resolving the problem ?
