Windows 10 USB Drivers for RM520N-GL
I have the same issue by switching RM551E-GL to RNDIS mode with at command AT+QCFG=“usbnet”,3
and it’s impossible to send at commands because ports com and lpt disappear. I tried in many pc without results. What do I have to do? Thanks and regards
Pls try to change the driver, I have sent it to you
No results. No ports on devices manager
I have the same issue with BG95m3
Hello,I looking for the USB firmware for the RM520N-GL.
Could I have a RM551E-GL pin diagram? Thanks and regards
Download Zone | Quectel
Hello, could I have the Windows 11 driver for the RM520N-GL please?
Received, thank you :slight_smile:
alsow need the same drivers and firmware for a RM520N-GL
I also looking for the firmwares for the RM520N-GL for linux and windows, would you be able to email them to me?
Thanks!
I have the same issue, my EC200U-EU is not detected even after setting RNDIS mode on through AT commands, please send me the correct driver at waajjddi@gmail.com and thank you in advance.
Hello
May I have the driver for Windows 10?
Thanks in advance
HI
Can You please send me driver for Windows 10 please.
Hello, could I have the Windows 10 driver for the RM520N-GL please?
