RG520NEUDB-M28-SGASA
Please give me an updated firmware.
Does the RM520NL not support eSIM?
Partial command list shows up, but the add_profile reported “coming soon” on previous firmware and just errors on current firmware.
AT+QGMR
RM520NGLAAR01A07M4G_01.203.01.203
AT+QESIM=?
+QESIM: "lpa_enable",(0-1)
+QESIM: "profile_brief"
+QESIM: "profile_detail",(1-8)
+QESIM: "eid"
+QESIM: "delete_profile",(1-8)
+QESIM: "nickname",(1-8),<nickname>
+QESIM: "def_svr_addr",<address>
+QESIM: "disable_profile",(1-8)
+QESIM: "enable_profile",(1-8)
AT+QESIM="add_profile",1
ERROR
ERROR
AT+QESIM="lpa_enable",1
AT+QESIM="profile_brief"
ERROR
Looking for the software called out in Quectel_RG50xQ&RM5xxQ_Series_eSIM_LPA_Application_Note_V1.0.pdf
This chapter describes how to add profiles by eSIM LPA with the help of the eSIM LPAd software installed
on your Linux PC.
Install USB driver and QMI_WWAN driver on your Linux PC. Contact Quectel Technical Supports to assist
in the installation of the drivers if necessary
@herbert.pan-Q
Could you send the link for eSIM LPAd software to quectel@gekco.org please?
Could I please get the latest firmware for the RM520N-GL and windows software package? Thanks!
May I have the latest firmware please.
Can I have the latest firmware for RM520N-GL and the eSIM LPAd software please
send to sv5qnf@live.com
Can you please provide the latest firmware for the RM520N-GL modem.
Currently running running
RM520N-GL
Revision: RM520NGLAAR01A07M4G
If this is the latest version then please ignore.
Thanks,
Scott
You actually want to run:
AT+QGMR
RM520NGLAAR01A07M4G_01.200.01.200
the “latest” that they sent me the link for last week was: _V0107_01.203.01.203
A08_200 is available and shared by @Silvia to me. I believe this is the last firmware for RM520N-GL
when was that shared?
I would really love to see a table for firmware versions per device…
A week back. Ask Silvia to send you the same
Unfortunately there is no option to see the firmware of devices as a repository
Currently running
RM520N-GL
Revision: RM520NGLAAR01A07M4G_01.201.01.201
Thank you
Could I please get the latest firmware:
RM520N-GL
RM520NGLAAR03A01M4G_01.202.01.202
RM520F-GL
RM520FGLBAR03A01M4G_01.200.01.200
Thanks!
Correction the email is SV5QNF@GMAIL.COM
I have sent them to you,pls check
