RM500U-EA latest firmware request
RM500UEAAAR03A12M2G_01.001.01.001 plz send latest one
I need the latest firmware for RM500Q-AE
Hello, I am using Quectel RM500U-EA module.
Module info:
Model: RM500U-EA
Firmware: RM500UEAAAR03A13M2G
After using the module in Ethernet router mode (M.2 to RJ45 adapter), the module no longer enables RF after reboot. AT+CSQ always returns 99,99, even though SIM is ready and CEREG registers. This looks like RF policy issue. AT commands and factory reset do not fix it. I would like to request: full factory firmware package, capable of resetting RF, for USB / MBIM usage (non-router). Please advise which firmware package should be used and provide flashing instructions. Linux/MacOS
Dear @Abhishek_Live
Dear @bpienkowski
I have sent to your email, please download and try.
We only have tool for Linux, not for Mac.
Dear @isaak
Hello Quectel Team,
I am using RM500U-EA with firmware RM500UEAAAR03A13M2G. The module connects to NR5G-SA (Jio India) but does not obtain an IP address.
Kindly share the latest firmware
Thank you.
Hello.
Where we get an update tool/flasher (with how-to Manual) for linux (ARM/Raspberry Pi)?
We also need the latest Firmware for RM500U-EA.
Current Version: RM500UEAAAR03A05M2G_01.001.01.001.
Thank you
Dear @Abhishek_Live
Dear @julsch-nc
Hi @silvia ,
could you send me some manual and binary or sources for lpad tools for RM520NEUDAR03A06M4G. I need to add esim profile and only by your legacy tools as I understand for this modem is possible. thank you in advance.
Hi @silvia !
Found this topic and I have the exact same problems as stated above.
Please send me a link (windows / linux) to upgrade my firmware.
ATI:
RM500U-EA
Revision: RM500UEAAAR03A06M2G
Thanks in advance!
Dear @Jdn333
Sorry about this, I don’t have permission to share, please contact with your supplier and get it.
Dear @Michael1
We have couple RM500U-EA devices with RM500UEAAAR03A13M2G_01.300.01.300 firmware.
Is newer firmware available? If yes please share.
Thank you
Dear @JoeMama
Hi Support Team,
I have a RM500UEAAAR03A12M2G_01.001.01.001 Is there a new firmware?
It also fails to switch the mode and does not see my SIM card
AT+QCFG=“usbnet”,2
+CME ERROR: 4
ATI
RM500U-EA
Revision: RM500UEAAAR03A12M2G
+QADBKEY: PBVN73_1_21_26
Thanks in advance!
Dear @TechNZ
Hey there,
would it be possible to send over the updated firmware (for Linux) and the AT command manual for the RM500U-EA, please? The current firmware version I have is RM500UEAAAR03A06M2G_01.001.01.001
Thanks in advance!
Hi Silvia,
Requesting the latest RM500U-EA firmware. Currently on RM500UEAAAR03A13M2G_01.300.01.3, redirected here by Maksim after opening a support ticket.
Two issues we’d like firmware to address:
  1. Continuous unsolicited +CME ERROR: 4 spam on all serial ports, starting at boot, independent of AT input. AT+CFUN=0 reduces but does not stop it.
  2. Periodic NCM data-path lockup (usb0 stops passing traffic, AT layer stays responsive, AT+CGPADDR still returns carrier IP, AT+CGACT? shows 1,1). Neither AT+CGACT cycle, AT+CFUN=1,1, nor USB sysfs re-authorize recovers - only a hardware power cycle does. cdc_ncm fails SET_NTB_FORMAT on re-bind, suggesting the Unisoc USB controller holds stale NTB state across VBUS-on resets.
Setup: BPI-R4 / OpenWrt 25.12 / kernel 6.12 / cdc_ncm, bridge mode (AT+QCFG="nat",0), NCM (AT+QCFG="usbnet",5).
Could you also share the Linux flashing tool/instructions?
Thanks!
