Dear @joshuasantiago
Please confirm which firmware on your module, in shield cover it showed RM500UEAAB.
They are different module.
(post deleted by author)
RM500UEAABR03A02M2G here @silvia
Hello!
Could i please get the latest firmware for my rm500u-ea?
this is the version i have now:
AT+GMR
RM500UEAAAR03A06M2G_01.001.01.001
I hope the new version fixes carrier aggregation and nsa mode, as right now i’m using it in a ZBT Z8102AX v2 and i get very low speeds.
did you get the firmware?
I have the same router and the module keeps resetting on 5G.
Will check and send via email. THX
can you send it to me too?
It is a customized firmware, we can’t share, please contact with your supplier.
Dear @xewonder
Hey Silvia i need the newest Firmware for the Rm500U-EA actual firmware version is: RM500UEAAAR03A11M2g_01.001.01.001
thx a lot !
Dear @Surfin_Troll
Hi @Silvia, I have RM500UEAAAR03A13M2G_01.300.01.300 currently installed, but for a few commands like AT+QCFG=“band”, it gives error +CME ERROR: 4. I’m not sure, but it looks like it is OEM locked.
So, can you please provide the firmware that allows me to select manual bands and lock carrier aggregation?
How can I find out when new firmware is released? So that our devices are always up to date!
Dear @vicky
For 5G , it use other AT command , I will send document to you via Message, please check later.
Dear @Taras_Kucherenko
Currently, you can contact with your supplier or ask us to provide.
Hello! I am also looking for the latest firmware. My modem is used in a openwrt based router from huastlink.
My current firmware is RM500UEAAAR03A06M2G_01.001.01.001.
The module works fine most of the time but it keeps disconnecting randomly. When it does, it also does not show up on the usb bus anymore.
Is this a know issue for my firmware version?
Please let me know if there is a new firmware availabe and if so how to flash it to my module.
BR
Dear @cynical.fluffs-9l
hi i am using this firmwareRM500UEAAAR03A13M2G.
Can you send me the at commands please and latest firmware?
Dear @lis59
