Dear @tttie
Dear @karolis
I have a RM500UEAAAR03A06M2G_01.001.01.001 Is there a new firmware?
ATI
RM500U-EA
Revision: RM500UEAAAR03A06M2G
+QADBKEY: P1KR27_9_19_4
Dear @irduranni
Hello Quectel Support,
I am using a Quectel RM500U-EA installed in a ZBT-Z8102AX-2SIM router running a custom OpenWrt firmware.
Modem information:
- Model: Quectel RM500U-EA
- Current firmware: RM500UEAAAR03A13M2G_01.300.01.300
- Router: ZBT-Z8102AX-2SIM
- Platform: MediaTek MT7981 / ARM64
- OpenWrt: 21.02-SNAPSHOT
- Router build: 25.1118_204421
- Mobile operator: Very Mobile / WINDTRE Italy (MCC/MNC 22288)
I am experiencing poor and inconsistent performance, especially when using 5G NSA.
I performed several tests directly through AT commands.
In automatic mode, the modem often stays on LTE Carrier Aggregation, for example:
LTE B20 (PCC) + B1 (SCC) + B3 (SCC)
while the NR carrier is not active:
+QENG: "NR5G-NSA",0,0,0,0,0,0,0,0,0,0,0
AT+QCAINFO also shows the LTE CA carriers but an empty NR carrier.
When LTE B20 is excluded, the modem can establish a real NSA connection using:
LTE B1 + NR n28
For example:
+QENG: "NR5G-NSA",222,88,404,-89,10,-5,152690,28,0,B0F6,0
and:
+QCAINFO: "SCC",152690,10,"NR N28",2,404,-89,-5,-71,10
However, performance with 5G NSA is poor. A representative speed test with B1+n28 was approximately:
- Download: 17.5 Mbps
- Upload: 1.7 Mbps
- Ping: 400 ms
By comparison, forcing LTE-only and allowing B1/B3/B7 (with the modem actually aggregating B1 and B3) produced substantially better download performance, approximately 27–36 Mbps, although latency and upload remain variable.
I also tested 5G SA:
AT+QNWPREFCFG="mode_pref"
+QNWPREFCFG: "mode_pref",NR5G
but:
AT+C5GREG?
+C5GREG: 0,0
so the modem did not register on 5G SA at this location.
EN-DC reports:
AT+QENDC
+QENDC: 1,1,1,0
The modem works and Carrier Aggregation is operational, but 5G NSA attachment/performance appears inconsistent and significantly worse than LTE-only in my tests.
Could you please confirm whether a newer stable firmware is available for RM500UEAAAR03A13M2G_01.300.01.300?
If available, could you please provide:
- The latest compatible RM500U-EA firmware package
- The recommended upgrade tool/method for Linux/OpenWrt ARM64
- Upgrade instructions
- Information about any firmware changes related to 5G NSA/EN-DC, Carrier Aggregation, NCM/USB networking, network registration or stability
I would also appreciate confirmation that the suggested firmware is fully compatible with my current branch RM500UEAAAR03A13M2G before flashing.
I can provide additional AT command logs if required.
Thank you.
