hi please check the passcode
Would it be possible to send me the latest Firmware for my:
ATI
RM500Q-AE
Revision: RM500QAEAAR11A02M4G
Current Version:
RM500QAEAAR11A02M4G_01.003.01.003
as well?
Just out of curiosity, are there already Windows on ARM drivers? If so, could you send them to me as well?
Hello there,
i’m unable to install/get after installing the module got visible / installed on Win.10…
device manager shows constant "not installed / no drivers)
Need the actual >Firmware and drivers for the RM500U-EA for Windows and Linux/ubuntu
Mail at: alexander@smart-velo.de
thx !
Dear @Surfin_Troll
Dear @bbathow
I have sent to your eamil, please check.
Please sumbit in related topic next time, thanks for your understanding.
Dear @silvia,
thanks for your support, the firmware upgrade worked and made the modem work much more reliable.
Can you give me more advice on how to post a firmware request next time?
Thank you in advance!
Kind Regards
Dear @bbathow
You can ask your provider firstly, they have access to get it.
Or submit a topic in forum to get it.
Current Firmware is: RM500UEAAAR03A08M2G_01.001.01.001
Dear @Surfin_Troll
(post deleted by author)
C:\Program Files (x86)\ADB & Fastboot++>adb shell ls -l /dev/ubi0_nr_runtimenv1
lrwxrwxrwx 1 root root 11 Nov 27 00:10 /dev/ubi0_nr_runtimenv1 → /dev/ubi0_5
C:\Program Files (x86)\ADB & Fastboot++>adb shell ls -l /dev/ubi0_data
lrwxrwxrwx 1 root root 12 Nov 27 00:10 /dev/ubi0_data → /dev/ubi0_20
C:\Program Files (x86)\ADB & Fastboot++>adb shell ls -l /dev/ubi0_userdara
ls: /dev/ubi0_userdara: No such file or directory
Dear @maxis1901
Why did you want to get the file?
I think I had shared the file to capture dump log for analyze.
I’d also like the latest firmware please I can’t get it to connect with mbim
Dear @nino
Please share your current firmware?
HI
I am getting
error: couldn’t connect the modem: ‘GDBus.Error:org.freedesktop.ModemManager1.Error.Core.Retry: Too much time waiting to get to a final state’
and generally low signal
firmware revision: RM500UEAAAR03A11M2G
# mmcli -m 1
General | path: /org/freedesktop/ModemManager1/Modem/1
| device id: 7b0a08477f74c3a1ffbf760d01ced2f456abae6e
Hardware | manufacturer: Quectel
| model: RM500U-EA
| h/w revision: UDX710_modem
| supported: gsm-umts, lte, 5gnr
| current: gsm-umts, lte, 5gnr
| equipment id: 869841060728372
System | device: /sys/devices/platform/soc/11200000.usb/usb2/2-1
| physdev: /sys/devices/platform/soc/11200000.usb/usb2/2-1
| drivers: cdc_mbim, option1
| plugin: quectel
| primary port: cdc-wdm0
| ports: cdc-wdm0 (mbim), ttyUSB3 (at), wwan0 (net)
Status | unlock retries: sim-pin (3)
| state: enabled
| power state: on
| signal quality: 9% (cached)
Modes | supported: allowed: 2g, 3g, 4g, 5g; preferred: none
| current: allowed: 2g, 3g, 4g, 5g; preferred: none
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: <redachter>
| registration: idle
3GPP EPS | ue mode of operation: ps-2
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/1
Dear @nino
I have sent the firmware to your email, please check.
For MBIM, please note as below. Could you try other mode?
When USBnet driver type of the module is configured to MBIM, the host controller can only
communicate with the module through MBIM protocol rather than AT commands.
cellularclass: 0001
voiceclass: 0001 - no-voice
simclass: 0002
dataclass: 8000003B
smscaps: 0003
controlcaps: 0003
maxsessions: 0008
deviceid: 869841060728372
firmwareinfo: RM500UEAAAR03A11M2G
hardwareinfo: UDX710_modem
root@OpenWrt:~# umbim -d /dev/cdc-wdm0 pinstate
Pin Unlocked
root@OpenWrt:~# umbim -d /dev/cdc-wdm0 subscriber
readystate: 0001 - initialized
simiccid: <integer>
subscriberid: <integer>
root@OpenWrt:~# umbim -d /dev/cdc-wdm0 registration
nwerror: 0000 - unknown
registerstate: 0001 - deregistered
registermode: 0001 - automatic
availabledataclasses: 0000 - (null)
currentcellularclass: 0001 - gsm
provider_id:
provider_name:
roamingtext:
I’ve realised that actually it might be the provider blocking the registration when it’s not associated to a phone imei? What can I specifically ask for so they can whitelist / enable me using the modem in a bananapi r3 mini?
Dear @nino
Do you configure the correct APN?
yes - I am suspecting the sim card is blocking my registration to the network because it’s not in a phone? not 100% certain.
flashed latest now, but I don’t think it will help - you have release notes?
opened a support ticket with the telco provider, but they seem oblivious - need to look maybe for so-called smartwatch subscription
Dear @nino
I have sent release note to you via Message, please check,
Is it possible to capture log on your side?
