RM500U-EA latest firmware request
Second modem after update is also damaged, same reboot after 30 seconds (15 cec. online)
RDY
+QUSIM: 1
+CPIN: READY
+QIND: PB DONE
+CFUN: 1
+QIND: SMS DONE
+CPIN: NOT READY - Reboot
Modem 1:
ati
RM500U-EA
Revision: RM500UEAAAR03A08M2G
I need key for ADB access for partition restore
AT+QADBKEY?
+QADBKEY: P1KR27_14_24_21
Modem 2:
AT+QADBKEY?
+QADBKEY: P1KR30_16_19_1
USB LOG Port com64.txt (969.8 KB)
Dear @maxis1901
Bdfore upgrade, everything is ok, right?
For your log, there are so many warning message, no useful information.
I have sent the ADB possword to you via Message, please check.
the ADB keys that you emailed me don’t work.
Two modems are broken immediately after the update?
Update again - no help. I can’t get into ADB, last option is only with the boot_pin - but I can’t find any information about it.
I’ve created a log, maybe it’s useful.
log.txt (18.0 KB)
Dear @maxis1901
What is your problem now? After upgrade, they are broken and reboot frequently or others. Please share the two version, before and after.
As you mentioned before, the module is getting hot, is there some hardware issue?
Please take a picture of your module, I need to confirm something.
The problem is this:
both worked well, but I suspect that one of them was too hot, I did an update (they emailed me the update), after the update the modem reboots every 30 seconds.
the second one worked well, but I also did an update and like the first one it now reboots every 30 seconds.
both modems were first updated with QFlash_V7.1_EN, after the problem arose with reboot, they were also treated with SPD_Upgrade_Tool and SPD_Factory_Tool, but that didn’t help, both modems reboot every 30 seconds
can i have rm500u-ea latest driver too? for windows and linux (just in case)
Dear @maxis1901
As we disscussed before, please provide debug log.
Dear @Hydra_Steel
please send me the latest one too RM500U
EMAIL:freeboom18@gmail.com
Dear @Jason_Ye
Can you send me both FWs ? latest and current one RM500UEAAAR03A06M2G_01.001.01.001. In case its not ok build, does latest supports downgrading to current one ?
send me windows drivers too..
thanks
Dear @thxthx
RM500UEAAAR03A06M2G_01.001.01.001 is the latest one.
I have sent the driver to you via message.
Hi @maxis1901
I had similar reboots(loosing connection every X sec) on R03A06 firmware until I found the solution. Could be that you are facing same issue than me. So, the solution is:
- Don’t band lock modem to both bands N1 and N66 ! Keep it locked to only one of these two !
- Don’t band lock modem to both bands N28 and N78 ! Keep it locked to only one of these two !
At my location I don’t even have N1 and N66 and modem was goin nuts if these two bands were locked (depends which first). Maybe modem has issue with 2100 MHz and B1 which I have.
At my location I have both N28 and N78, but again, modem is not working properly if it is locked to both bands.
@silvia I have sent you the findings on how the connection loss occurs on the latest R03A06 firmware.
This RM500UCNAAR01A19M2G_01.001.01.001
Dear @Jason_Ye
Hi, I’d be interested in Windows drivers and original firmware.
Dear @economyClass
What do you mean of original firmware?
I will sent the windows driver to you via Message, please check later.
(post deleted by author)
need ADB key
AT+QADBKEY?
+QADBKEY: P1KR30_14_31_12
Enter the AT+QADBKEY? response: P1KR30_14_31_12
and please file size of user data
according to Packinfo = FileSize,0x01B2000 - too small
according to default = 0x27B8000 - false - too large
