Hi @jacekk
Please provide your email address and I will send you the relevant information via email.
Please note:
The distance between the rover station and the base station should not exceed 15 km, otherwise the accuracy of RTK cannot be guaranteed.
Hy , i have also LC29HDA i need firmware please
- Please use the “$PQTMVERNO*58” command to check the version of the module and let me know.
- Please provide your email address and I will send you the relevant information via email.
Hi @CGM_technology
Please use QGNSS tool to download the firmware. QGNSS tool download link: QGNSS_V1.10_CN | 移远通信 (quectel.com.cn)
I have sent you the relevant information via email, please check.
Hi @CGM_technology
Your download interface looks wrong.
Please use QGNSS V1.0, refer to the following two pictures.
your link sends me to QGNSS_V2.0 only i cant find version 1.0 on site , whenever i try it gives me QGNSS_V2.0 , can you please provide link?
If can help
or v1.8 on and be able to upgrade to 1.10
Can you send me the latest firmware for LC29H(BS)?
My device returns
PQTMVERNO,LC29HBSNR11A01S,2023/02/13,10:14:06*27
thanks
Simon
Hi @Sim60
LC29HBSNR11A01S is already the latest firmware.
I’m trying to install two LC29HDA modules for GPS RTK (One for base and one for the rover).
I would have the documentation explaining the procedure to follow for installation and configuration of both modules.
I would have also the latest firmware file.
Thanks in advance for that.
Regards
Hi @mby90300
Many thanks for your very fast answer. I will check your documentation and will come back after if required. Thanks again !
Hi again,
And thank you for the documentation where I found a procedure for RTK installation setup.
For that, I understand that I need :
the QGNSS software : Could you please send me the last version ?
NTRIP client login informations for getting RTK data monitor informations (Could I get it for free ?)
Thanks again for the good support.
Regards
Hi @mby90300
The download link for QGNSS is as follows:https://www.quectel.com.cn/download/qgnss_v1-4
You need to purchase the NTRIP client login information yourself, we do not provide free accounts.
Thanks for your reply. Just a last information : Could you please confirm that NTRIP subscription is necessary only if we don’t have a local base station and in the case we will install only one rover that need corrections coming from NTRIP server ?
If I install both base and rover, it is only required to have a simple ‘radio line’ between base and rover in order corrections could be directly transmitted (without changes except the radio transmission) from base to rover.
Thanks again
Hi @mby90300
If you do not have a local base station, you must inject differential data into the receiver via NTRIP.
If you have a receiver and a base station, you can simply send the base station data to the receiver via any method such as serial port/network.
Regards
Hi @dung_nguyen_van
