Can I get the firmware for LC29HDA?
Current: LC29HDANR11A02S_RSA
Looks like I can’t get GPS or RTK to work.
I have the LC29HBSMD it outputs strange characters and the firmware is out of date.
On starting I get:
[2025-02-02 16:53:36.876 Uart Tx:0008 B] QGae
[2025-02-02 16:53:36.973 Uart Rx:0013 B] PAIR012*39
[2025-02-02 16:53:37.211 Uart Tx:0015 B] $PQTMVERNO*58
[2025-02-02 16:53:37.211 Uart Tx:0018 B] $PQTMEGMR,R,5*62
[2025-02-02 16:53:37.288 Uart Rx:0084 B] $PQTMVERNO,LC29HBSNR11A01S,2023/02/13,10:14:06*27
$PQTMEGMR,OK,P1Y24DS25000119*26
[2025-02-02 16:53:37.806 Uart Rx:0165 B] Ó>ÝaÀÍP¦B1ÓC-a$1Ò@xú_ÓCÍa¶F@<«ÓDma$1Ò@ä±ÓFMa#W@ ³ÔÓEa$1Ð@ _
[2025-02-02 16:53:38.793 Uart Rx:0165 B] Ó>ÝaÀÍP¦B1ÓC-a$Ar@x]ÏÓCÍa¶V2@j_ÓDma$Ar@ä*!ÓFMa#f²@®%ÒÓEa$Ap@ ·Ï
[2025-02-02 16:53:39.797 Uart Rx:0165 B] Ó>ÝaÀÍP¦B1ÓC-a$Q@Û{ÓCÍa¶eÒ@K(ÓDma$Q@G ±ÓFMa#vR@¬}ÓEa$Q@&
[2025-02-02 16:53:40.785 Uart Rx:0165 B] Ó>ÝaÀÍP¦B1ÓC-a$²@|íYÓCÍa¶ur@asÓDma$²@à·ÓFMa#
ò@ DÓEa$`°@aY
[2025-02-02 16:53:41.790 Uart Rx:0165 B] Ó>ÝaÀÍP¦B1ÓC-a$pR@~µÓCÍa¶ @òËÓDma$pR@âÂüÓFMa#@bÓEa$pP@_
[2025-02-02 16:53:42.794 Uart Rx:0165 B] Ó>ÝaÀÍP¦B1ÓC-a$ò@}+ÓCÍa¶²@§»ÓDma$ò@ã
ÅÓFMa#¥2@`EHÓEa$ð@+
[2025-02-02 16:53:43.799 Uart Rx:0165 B] Ó>ÝaÀÍP¦B1ÓC-a$@<ÆÓCÍa¶¤R@WÓÓDma$@K(ÓFMa#´Ò@¦¬NÓEa$@wÖÆ
[2025-02-02 16:53:44.804 Uart Rx:0165 B] Ó>ÝaÀÍP¦B1ÓC-a$2@eýÓCÍa¶³ò@afÓDma$2@sÓFMa#Är@¦ ÞÓEa$0@æ
Can you supply a newer firmware:
Finally, I need to use this unit as a Rover, can I give it a command to put it into Rover mode? I have tried $PQTMCFGRCVRMODE,W,1*2A but nothing changes.
Thank you.
Rolf
Hi, @george.gao can I have latest FW for BS module also?
Current ver is $PQTMVERNO,LC29HBSNR11A01S,2023/02/13,10:14:06*27
Hi @george.gao
I got two modules, LC29HDA with LC29HDANR11A03S_RSA,2024/03/19,13:55:31
and LC29HEA with LC29HEANR11A03S_RSA,2023/10/31,16:52:14
Could you advise regarding the firmware? With both of them I cannot proceed beyond a “Single” fix…
Thanks,
Dmitry
Hi @Dmitry_K
Both of these are the latest versions.
Can’t single-point positioning, how did you test it? Can you take a complete picture of the test environment and test module including the antenna?
Hi @Dmitry_K
Have you injected base station data into the module? If yes, what base station information did you inject? How far is it from you?
Hi George,
I did multiple tests (in all of them the “external” station is BSHM00ISR0 from IGS network:
BTW - could you suggest a sequence of commands, returning LC29HEA/HDA devices to a factory-default configuration?
Thanks,
Dmitry
caster is not useful with 1076 only …also posted poorly antennas that may impact performance.
Configure one module as base,fix location for 1005 rtcm value
$PQTMCFGSVIN,W,2,0,0,x,y,z*3B # set base location in XYZ coords
or the same in lat,lon.hei
$PAIR604,1,1,lat,lon,hei*CKSUM
add $PAIR436,1*26 ==> set RTCM3.x output with satellite ephemeris
for reset modules try
$PAIR382,1*2E → Test command for lock system sleep enabled
$PAIR003*39 → power off GNSS system
$PAIR514*3A Clear the current configuration and restore the default settings set via $PAIR
$PAIR512*3C clear all data
$PQTMRESTOREPAR*13 # restore $PQTM params to default
$PQTMSAVEPAR*5A
$PAIR023*3B reboot module
$PAIR007*3D → Full cold start and clears system and user configurations
U can use also rtklib by putting both modules in only rtcm output (as base) and do solution.
Regards
Please find below the station info:
BSHM00ISR_20230403.pdf (62.1 KB)
@george.gao
Could you provide me with firmware updates please?
I have two modules:
Also: the BS version ALWAYS responds with PAIR012. Whatever message i sent…
Thanks in advance
Hi @WernerT
I have sent you the relevant information via email, please check.
@george.gao I have the same problem. Can i get the information? Thanks a lot
My current version of firmware is:
$PQTMVERNO,LC29HDANR11A03S_RSA,2024/03/19,13:55:31*20
I am not seeing any Beidou satellites. Could it be a version issue? If there is a newer version please send it my way. Thanks!
Hi @Piotr_Soltys @David_Rice
Hi @David_Rice
Please test in an open environment and check whether the antenna specification you are using supports the BDS satellite frequency band.
Hi!
I need latest firmware
$PQTMVERNO,LC29HDANR11A01S_RSA,2023/03/02,12:43:39*21
Thx Balazs
I have the same problem (BS version ALWAYS responds with PAIR012). Can i get the information?
Ok. I found the solution. The problem was a strangely behaving usb-ttl converter on the ch340G chip
