Update firmware tool for EG800K module on Linux
I am looking for a firmware update tool for the EG800K-EU/CN module for Linux (working on Raspberry PI). To upgrade the module via UART or USB (preferred). I found on this post
Updated firmware for EG800Q? the QDownloaderProj for Linux, but it seems to be more for the EG800Q module.
The question is, can I also use this tool for the EG800K module too? If not, can you provide me sources to another tool?
Best,
Sev
I have sent it to your email, pls check
Thanks Herbert to pointing me the the QDownloader,
As far as I can see you need to provide a BIN/PAC file, in the latest firmware package I got (which is a ZIP compressed file) contains various files. There is a file named “firmware.bin”, is this the only file I need for upgrading?
What are the other files for?
  • bootloader.ubi
  • cp.bin
  • download.json
  • dsp.bin
  • EG800KEULCR07A05M04.json
  • firmware.bin
  • flasher.img
  • flashinfo.bin
  • fota.json
  • fuse.dat
  • partition.bin
  • preboot.img
  • ReliableData.bin
  • rf.bin
  • system.img
What also brings me to the question, is there some tool for Linux (like QFlash for Windows) which is able to flash the whole ZIP file for the EG800K?
@herbert.pan-Q is it also possible to get the latest source for Qflash-tool for Linux, regarding to the manual which can be found in the Quectel Download-Section?
I have sent you the user manual of QDloader via email. It is recommended that you refer to the manual document first
thanks, do you also have a description of the files (see above), couldn’t find that in the documentation.
