Udx710 5G router new firmware where to download?
udx710 5G router new firmware where to download?
RG500UEAABxISP
Mar 24 22:21:10.371 udx710-module user.info atrouter[2741]: [Quectel][ql_at_response_segmetation_func] [597]:[rami]:block:11 num:1, operpoint=1148.
RG500UEAAB is from Quectel.
But I have never seen the RG500UEAABxISP.
Could you provide the photo of the Quectel modem and the IMEI on it?
Whether it is Quectel Open Solution firmware?
IMEI 867626050188790
IMSI 525100002993576
ICCID 89651001100029935765
SW RG500UEAABR02A01M2G
RSRP -91dBm
RSRQ -12dB
SINR -2
PCID 287
EARFCN 3650
RSSI -64dBm
Network LTE-NR
SIM Status READY Aux
Mar 25 13:33:24.204 udx710-module user.info atrouter[2741]: [Quectel][ql_at_response_segmetation_func] [597]:[rami]:block:8 num:1, operpoint=10.
Mar 25 13:33:24.204 udx710-module user.info atrouter[2741]: [Quectel][ql_at_response_segmetation_func] [597]:[rami]:block:36 num:1, operpoint=-7456,0.
Mar 25 13:33:24.204 udx710-module user.info atrouter[2741]: [Quectel][ql_at_response_segmetation_func] [597]:[rami]:block:45 num:1, operpoint=0.
Mar 25 13:33:24.204 udx710-module user.info atrouter[2741]: [Quectel][ql_at_response_segmetation_func] [597]:[rami]:block:21 num:1, operpoint=1700.
Mar 25 13:33:24.205 udx710-module user.info atrouter[2741]: [Quectel][ql_at_response_segmetation_func] [597]:[rami]:block:37 num:1, operpoint=0.
Mar 25 13:33:24.235 udx710-module user.info kernel: [19468.261001] c1 sprd_cpu_cooling: cpu0 temp:77411 target_freq:1352000 online:2 qos_cpu:2 power:334
Mar 25 13:33:28.106 udx710-module user.debug sprd-ril[2785]: [3025] readline Channel0: AT< +SPUSATENDSESSIONIND
Mar 25 13:33:28.106 udx710-module user.debug sprd-ril[2785]: [3025] grabPartialWakeLock s_wakeuplockobtain = 0
Mar 25 13:33:28.106 udx710-module user.debug sprd-ril[2785]: acquire_wake_lock start
Mar 25 13:33:28.106 udx710-module user.debug sprd-ril[2785]: acquire_wake_lock write return 8
Mar 25 13:33:28.106 udx710-module user.debug sprd-ril[2785]: acquire_wake_lock end
Mar 25 13:33:28.106 udx710-module user.info sprd-ril[2785]: [3025] RIL_onUnsolicitedResponse RIL_SOCKET_1 UNSOLICITED: UNSOL_STK_SESSION_END
I will send you the RG500UEAABR03A04M4G_01.001.01.001
I am not sure whether it is customerized firmware. It is better to check it with the guy you bought from.
RG500UEAABR03A04M4G_01.001.01.001 this is latest?
or
Current Version
RG500UEAABxISPv3.2.2543.13.41
the shop selling this product does not want to disclose which vendor in China he got this product
Could you send AT command on that device?
Try
ATI
That is the default firmware version.
SW: RG500UEAABR03A03M4G
OC: RG500UEAAB-D11-SNASA
SN: P1Y23K719000163
IMEI: 867626050188790
You can get the default firmware verison from imei.quectel.com with the IMEI.
As you mentioned it is RG500UEAABR02A01M2G which is not the same with RG500UEAABR03A03M4G. That might be a problem.
You could flash the Quectel modem with RG500UEAABR03A04M4G_01.001.01.001 I just sent.
[can send me default software RG500UEAABR03A03M4G?
in case I need to revert back if new software got problem.
there was guy said got problem with NEW software?
preservio
1
3d
I was given this firmware by Quectel support (RG500UEAABR03A04M4G_01.001.01.001)
Firstly i was able to plug in the USB and install Quectel_Windows_USB_Driver(U)_For_ECM_RNDIS_V1.0.14 which gave me a bunch of COM ports and USB modem functionality. Using the AT driver and PORT number i was able to send AT+QDOWNLOAD=1 and reboot the device into a working recovery mode. I then used QFLASH (latest version) to send the above PAC file to the device.
After reboot, the modem no longer starts, i can still login through UART session and login with ‘user’ into a highly restrictive shell. However the modem functionality doesn’t work anymore. there is no LAN/WIFI, and the physical RESET/WPS buttons no longer work.
Any IDEA how i can restore this device or get the modem working again?
When i boot up i am able to go into DEBUG mode. Where i have captured the logs…
There could not exists that kind of bugs.
