some more logs:
Sun Jun 16 07:37:23 2024 : usb-modeswitch Add : 4-1: Manufacturer=Quectel Product=RG500Q-EA Serial=42cdca6b 2c7c 0800
Sun Jun 16 07:37:23 2024 : usb-modeswitch 1 *****************************************************************
Sun Jun 16 07:37:23 2024 : usb-modeswitch 1 * Start of Modem Detection and Connection Information
Sun Jun 16 07:37:23 2024 : usb-modeswitch 1 * Product=RG500Q-EA 2c7c 0800
Sun Jun 16 07:37:23 2024 : usb-modeswitch 1 Found Modem at 4-1 in Cfg#= 1 from 1 available
Sun Jun 16 07:37:23 2024 : usb-modeswitch Ignoring Linux Hub
Sun Jun 16 07:37:23 2024 : usb-modeswitch 1 * Device at 4-1 does not have a switch data file
Sun Jun 16 07:37:33 2024 : usb-modeswitch 1 *****************************************************************
Sun Jun 16 07:37:33 2024 : usb-modeswitch 1 * Modem at 4-1 switched to : 2c7c:0800
Sun Jun 16 07:37:33 2024 : Protofind 2c7c/0800 Number Interfaces w/drivers : 5
Sun Jun 16 07:37:33 2024 : Protofind 2c7c/0800 Driver Name : 0 option
Sun Jun 16 07:37:33 2024 : Protofind 2c7c/0800 Driver Name : 1
Sun Jun 16 07:37:33 2024 : Protofind 2c7c/0800 Driver Name : 2 option
Sun Jun 16 07:37:33 2024 : Protofind 2c7c/0800 Driver Name : 3 option
Sun Jun 16 07:37:33 2024 : Protofind 2c7c/0800 Driver Name : 4 qmi_wwan
Sun Jun 16 07:37:33 2024 : usb-modeswitch 1 * ProtoFind returns : 2
Sun Jun 16 07:37:33 2024 : usb-modeswitch 1 Found Modem 1
Sun Jun 16 07:37:34 2024 : usb-modeswitch 1 Connecting a QMI Modem
Sun Jun 16 07:37:34 2024 : Create Connection 1 Start Connection
Sun Jun 16 07:37:34 2024 : Create Connection 1 Modem 1 WDM Device : cdc-wdm0
Sun Jun 16 07:37:34 2024 : Create Connection 1 Start QMI Connection
Sun Jun 16 07:37:39 2024 : Create Connection 1 Modem 1 QMI Comm Port : /dev/ttyUSB2
Sun Jun 16 07:37:39 2024 : PreConnect 1 Running PreConnect script
Sun Jun 16 07:37:43 2024 : Create Connection 1 Quectel Unsolicited Responses Disabled
Sun Jun 16 07:37:44 2024 : Band Mask 1
Sun Jun 16 07:37:44 2024 : Band Mask 1 Modem PID : 0800
Sun Jun 16 07:37:44 2024 : Band Mask 1 Modem Model : RG500Q-EA
Sun Jun 16 07:37:45 2024 : Band Mask 1
Sun Jun 16 07:37:45 2024 : Band Mask 1 Quectel Response : AT+QNWPREFCFG=“lte_band”
+QNWPREFCFG: “lte_band”,1:2:3:4:5:7:8:12:13:14:17:18:19:20:25:26:28:29:30:32:34:38:39:40:41:42:43:46:48:66:71
Sun Jun 16 07:37:45 2024 : Band Mask 1 AT+QNWPREFCFG=lte_band:+QNWPREFCFG::lte_band:1:2:3:4:5:7:8:12:13:14:17:18:19:20:25:26:28:29:30:32:34:38:39:40:41:42:43:46:48:66:71:OK:
Sun Jun 16 07:37:46 2024 : Band Mask 1
Sun Jun 16 07:37:48 2024 : Band Mask 1 EM160/RM500 AT+QNWPREFCFG=nsa_nr5g_band:+QNWPREFCFG::nsa_nr5g_band:1:2:3:5:7:8:12:20:25:28:38:40:41:48:66:71:77:78:79:OK:
Sun Jun 16 07:37:49 2024 : Band Mask 1 EM160/RM500 AT+QNWPREFCFG=nr5g_band:+QNWPREFCFG::nr5g_band:1:2:3:5:7:8:12:20:25:28:38:40:41:48:66:71:77:78:79:OK:
Sun Jun 16 07:37:52 2024 : Band Mask 1
Sun Jun 16 07:37:52 2024 : Band Mask 1 LTE Band Mask : 00000000000000420000A7E2BB0F38DF
Sun Jun 16 07:37:52 2024 : Band Mask 1 5G NSA Band Mask : 0000000000007042000081A0090808D7
Sun Jun 16 07:37:52 2024 : Band Mask 1 5G NA Band Mask : 0000000000007042000081A0090808D7
Sun Jun 16 07:38:15 2024 : Get Profile 1 Modem 1 is Quectel RG500Q-EA
Sun Jun 16 07:38:15 2024 : Get Profile 1 Default Profile Used
Sun Jun 16 07:38:16 2024 : SimLock 1 Not Locked
Sun Jun 16 07:38:16 2024 : Create Connection 1 Profile for Modem 1 sets interface to WAN1
Sun Jun 16 07:38:16 2024 : Create Connection 1 Modem 1 is using WAN1
Sun Jun 16 07:38:16 2024 : Create Connection 1 Using Provider assigned DNS
Sun Jun 16 07:38:16 2024 : Create Connection 1 000000,internet,Default,gdata,1,gdata,0,IPV4
Sun Jun 16 07:38:16 2024 : TTL Settings 1 Checking TTL
Sun Jun 16 07:38:16 2024 : TTL Settings 1 Checking HL
Sun Jun 16 07:38:16 2024 : TTL Settings 1 Deleting HL on interface wwan0
Sun Jun 16 07:38:24 2024 : Create Connection 1 000000,internet,Default,gdata,1,gdata,0,IPV4
Sun Jun 16 07:38:24 2024 : Lock Provider Check ISP Lock
Sun Jun 16 07:38:25 2024 : Create Connection 1 Pincode in script
Sun Jun 16 07:38:25 2024 : Create Connection 1 Attempting to Connect Modem 1
Sun Jun 16 07:38:25 2024 : Check Connection 1 Check Conn running
Sun Jun 16 07:38:26 2024 : Check Connection 1 7
Sun Jun 16 07:38:27 2024 : Create Connection 1 PDP Type selected in the Connection Profile: “IP”, active: “IP”
Sun Jun 16 07:38:37 2024 : Create Connection 1 Using Netifd Method
Sun Jun 16 07:38:37 2024 : QMI Connect Stopping network wan1
Sun Jun 16 07:38:37 2024 : QMI Connect Starting QMI
Sun Jun 16 07:38:46 2024 : Check Connection 1 6
Sun Jun 16 07:39:06 2024 : Check Connection 1 5
Sun Jun 16 07:39:26 2024 : Check Connection 1 4
Sun Jun 16 07:39:37 2024 : QMI Connect 1 WDA-GET-DATA-FORMAT is “raw-ip”
Sun Jun 16 07:39:37 2024 : QMI Connect 1 Device does not support 802.3 mode. Informing driver of raw-ip only for wwan0 ..
Sun Jun 16 07:39:37 2024 : QMI Connect 1 Waiting for network registration
Sun Jun 16 07:39:38 2024 : QMI Connect 1 Registration State : registering_denied
Sun Jun 16 07:39:38 2024 : QMI Connect 1 Network registration failed (reason: ‘registering_denied’)
Sun Jun 16 07:39:42 2024 : Modem Restart/Disconnect 1 Hard modem reset done
Sun Jun 16 07:39:42 2024 : QMI Connect Stopping network wan1
