The latest firmware for BC660K-GL
because we are not able to made a update thought the UART because of the to high baud rate needed, so I will try to update the BC660 over the air with a “old” sim card I found and worked well with the BC660KGLAAR01A04 revision. So on each of our 300 boards we should do a FOTA update before insert the new sim card. Do you know which firmware bug affect the BC660KGLAAR01A04 revision to be not compatible with some sim card ? it should be easier if we have a workaround in place of updating each module.
Hello @herbert.pan-Q,
could you send me the latest firmware for BC660K-GL, please?
Thanks!
Hi @herbert.pan-Q , can you sent me latest firmware and documents for BC660K-GK please.
Hello, can you send me the DFOTA Differential Upgrade package to be able to put it on a website and made a FOTA upgrade . cuurent firmware is BC660KGLAAR01A04.
Thanks,
https://dfota.quectel.com:8443/login
pls try the website
Hello. Im using BC660KGLAAR01A05_01.202.01.202 firmware - is it the latest or somewhere i can find any newer release?
it is the latest version
Could you send me the latest firmware for BC660K-GL?
Could you also send me the latest firmware for the BC660K-GL, the firmware version I have now is BC660KGLAAR01A05_01.202.01.202.
Best regards
Could you send me the latest firmware for BC660K-GL? Thanks.
You sent it to me before but I did not download it in time and the link does not work now.
I have sent it to your email,pls check again
Best Regards
Hello , please send me the latest firmware of BC660K-GL to arash@sensemi.com
