From the UART debug I can have some info, I don’t know how to enable USB or fastboot mode in order to upload a new system.
Log from boot on UART debug :
Format: Log Type - Time(microsec) - Message - Optional Info
Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic
S - QC_IMAGE_VERSION_STRING=BOOT.BF.3.1.2.C2-00037
S - IMAGE_VARIANT_STRING=DAASANAZA
S - OEM_IMAGE_VERSION_STRING=quectel
S - Boot Config, 0x000000e1
B - 1566 - PBL, Start
B - 4542 - bootable_media_detect_entry, Start
B - 59759 - bootable_media_detect_success, Start
B - 59763 - elf_loader_entry, Start
B - 60860 - auth_hash_seg_entry, Start
B - 61118 - auth_hash_seg_exit, Start
B - 74745 - elf_segs_hash_verify_entry, Start
B - 133933 - PBL, End
B - 146552 - SBL1, Start
B - 204167 - boot_flash_init, Start
D - 0 - boot_flash_init, Delta
B - 210816 - boot_config_data_table_init, Start
D - 7289 - boot_config_data_table_init, Delta - (0 Bytes)
B - 222711 - CDT version:3,Platform ID:8,Major ID:1,Minor ID:0,Subtype:0
B - 228872 - pm_device_init, Start
B - 232196 - pm_device_init, TEST - MSM8909 detected
B - 237595 - pm_device_init, INFO - PM8909 is selected
B - 251960 - PM_SET_VAL:Skip
D - 21441 - pm_device_init, Delta
B - 253333 - sbl1_ddr_set_params, Start
B - 255742 - cpr_init, Start
D - 0 - cpr_init, Delta
B - 261385 - Pre_DDR_clock_init, Start
D - 183 - Pre_DDR_clock_init, Delta
D - 0 - sbl1_ddr_set_params, Delta
B - 274286 - pm_driver_init, Start
B - 280966 - → Charge init
B - 281210 - battery good, boot up
B - 282247 - boot up
B - 10 - Current status
D - 11163 - pm_driver_init, Delta
B - 297527 - clock_init, Start
D - 152 - clock_init, Delta
B - 297924 - Image Load, Start
D - 25681 - QSEE Image Loaded, Delta - (490280 Bytes)
B - 323666 - Image Load, Start
D - 274 - SEC Image Loaded, Delta - (2048 Bytes)
B - 332084 - sbl1_efs_handle_cookies, Start
D - 640 - sbl1_efs_handle_cookies, Delta
B - 338672 - Image Load, Start
D - 13084 - RPM Image Loaded, Delta - (157136 Bytes)
B - 351787 - Image Load, Start
D - 35685 - APPSBL Image Loaded, Delta - (570264 Bytes)
B - 387502 - QSEE Execution, Start
D - 427 - QSEE Execution, Delta
B - 393206 - SBL1, End
D - 248941 - SBL1, Delta
S - Throughput, 34000 KB/s (1219728 Bytes, 35803 us)
S - DDR Frequency, 400 MHz
Android Bootloader - UART_DM Initialized!!!
[0] welcome to lk
[0] SCM call: 0x2000601 failed with :fffffffc
[0] Failed to initialize SCM
[10] platform_init()
[10] target_init()
[50] SDHC Running in HS200 mode
[50] Done initialization of the card
[60] pm8x41_get_is_cold_boot: cold boot
[60] Waiting for the RPM to populate smd channel table
[60] Not able to search the panel:
[70] panel_operating_mode=0x0
[120] ERROR: Splash image header invalid
[150] Config MIPI_VIDEO_PANEL.
[300] dsi panel init error
[300] Turn off MIPI_VIDEO_PANEL.
[380] Not able to search the panel:
[380] panel_operating_mode=0x0
[480] ERROR: Splash image header invalid
[510] Config MIPI_VIDEO_PANEL.
[640] Panic Lut0 512 Lut1 fff Robest 0
[640] Turn on MIPI_VIDEO_PANEL.
[660] Video lane tested successfully
CTRL+C: enter instruction mode
CTRL+C: out instruction mode
input FCT : enter instruction mode
[840] is_enter_fctmode ch:�
enter next loop
out fct instruction mode
[840] Recovery command: 32 normal1
[850] Unable to locate /bootselect partition
[850] Loading (boot) image (18632704): start
[980] Loading (boot) image (18632704): done
[990] use_signed_kernel=1, is_unlocked=1, is_tampered=0.
[990] Uncpmpressed kernel in use
[990] Kernel image not patched…Unable to locate dt offset
[1020] Best match DTB tags 245/00000008/0x00000000/0/1000d/0/0/0/9119dcac/30a19
[1030] Using pmic info 0x1000d/0x0/0x0/0x0 for device 0x1010d/0x0/0x0/0x0
[1030] display kernel cmdline: mdss_mdp3.panel=1:dsi:0:qcom,mdss_dsi_hx8394f_720p_video:1:none:cfg:single_dsi
[1040] cmdline: noinitrd ro console=ttyHSL0,115200,n8 androidboot.hardware=qcom ehci-hcd.park=3 msm_rtb.filter=0x37 lpm_levels.sleep_disabled=1 rootwait androidboot.bootdevice=7824900.sdhci androidboot.bootdevice=7824900.sdhci androidboot.serialno=3dca6203 andro[1060] Updating device tree: start
[1080] Updating device tree: done
[1080] Turn off MIPI_VIDEO_PANEL.
[1080] Continuous splash enabled, keeping panel alive.
[1090] Channel alloc freed
[1100] booting linux @ 0x80008000, ramdisk @ 0x82000000 (0), tags/device tree @ 0x81e00000
Log from booting with Ctrl + C pressed :
B - 59774 - bootable_media_detect_success, Start
B - 59778 - elf_loader_entry, Start
B - 60874 - auth_hash_seg_entry, Start
B - 61134 - auth_hash_seg_exit, Start
B - 74761 - elf_segs_hash_verify_entry, Start
B - 133948 - PBL, End
B - 145790 - SBL1, Start
B - 203069 - boot_flash_init, Start
D - 30 - boot_flash_init, Delta
B - 209687 - boot_config_data_table_init, Start
D - 7259 - boot_config_data_table_init, Delta - (0 Bytes)
B - 221491 - CDT version:3,Platform ID:8,Major ID:1,Minor ID:0,Subtype:0
B - 227652 - pm_device_init, Start
B - 230946 - pm_device_init, TEST - MSM8909 detected
B - 236283 - pm_device_init, INFO - PM8909 is selected
B - 250649 - PM_SET_VAL:Skip
D - 21380 - pm_device_init, Delta
B - 252052 - sbl1_ddr_set_params, Start
B - 254431 - cpr_init, Start
B - 260073 - Pre_DDR_clock_init, Start
B - 272975 - pm_driver_init, Start
B - 279654 - → Charge init
B - 279898 - battery good, boot up
B - 280935 - boot up
D - 11285 - pm_driver_init, Delta
B - 296216 - clock_init, Start
B - 296612 - Image Load, Start
D - 25803 - QSEE Image Loaded, Delta - (490280 Bytes)
B - 322446 - Image Load, Start
D - 244 - SEC Image Loaded, Delta - (2048 Bytes)
B - 330894 - sbl1_efs_handle_cookies, Start
B - 337452 - Image Load, Start
D - 13023 - RPM Image Loaded, Delta - (157136 Bytes)
B - 350506 - Image Load, Start
D - 35502 - APPSBL Image Loaded, Delta - (570264 Bytes)
B - 386069 - QSEE Execution, Start
D - 396 - QSEE Execution, Delta
B - 391772 - SBL1, End
D - 248239 - SBL1, Delta
S - Throughput, 34000 KB/s (1219728 Bytes, 35619 us)
[0] welcome to lk
[10] target_init()
[680] aboot_init ch: 3
Please input your instruction:
PINTEST: test gpio(s) connectivity.
fastboot: enter fastboot mode.
[3010] aboot_init ch: d
aboot_init: invalid cmd .
