I think, I’ve found the way in order to create uploadable files with the method described in the SC20_inux_Packaging_&_Download_On_Ubuntu_Guide.
I’ve now the Quectel_Emmc folder with the differents ext4 files, the differents mbn files, the rawprogram_unsparse.xml and the patch0.xml.
I can see the module with the lsub command :
Bus 002 Device 014: ID 05c6:9008 Qualcomm, Inc. Gobi Wireless Modem (QDL mode)
But when I’ve trying the fh_loader command :
Quectel_Emmc$ …/fh_loader -p /dev/ttyUSB0 -s 13:prog_emmc_firehose_8909_ddr.mbn
Binary build date: Oct 11 2018 @ 20:08:09
QSAHARASERVER CALLED LIKE THIS: '…/fh_loader -p /dev/ttyUSB0 -s 13:prog_emmc_firehose_8909_ddr.mbn 'Current working dir: /home/gilou/Documents/jimini/Base_image/SC20_Linux_Unpacking_tool_20200907/Quectel_Emmc
Sahara mappings:
2: amss.mbn
6: apps.mbn
8: dsp1.mbn
10: dbl.mbn
11: osbl.mbn
12: dsp2.mbn
16: efs1.mbn
17: efs2.mbn
20: efs3.mbn
21: sbl1.mbn
22: sbl2.mbn
23: rpm.mbn
25: tz.mbn
28: dsp3.mbn
29: acdb.mbn
30: wdt.mbn
31: mba.mbn
13: prog_emmc_firehose_8909_ddr.mbn
ERROR: function: rx_data:265 Timeout Occured, No response or command came from the target!
ERROR: function: sahara_main:854 Sahara protocol error
ERROR: function: main:265 Uploading Image using Sahara protocol failed
Can you help me?
Thank you.
