Good morning,
I purchased the module (200€) from Alibaba in october and I installed it on a M.2 to 5g ethernet adapter. After a wrong at command in November (at+qcfg= usbmode or usbnet) it’s impossible to see lpt and .com ports in windows, linux etc. What do I have to do? Do I have to think that I waste my money and that my module is broken after 15 days? Is there a way to reset it? Quectel has to be thoughtful with his customers
Hi @minkows
In Linux could you show me the
lsusb
lsusb -t
I’m sorry for the delay.
Here below the result… with usb modem connected.
luca@LUCA-NB:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
luca@LUCA-NB:~$ lsusb -t
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=vhci_hcd/8p, 480M
/: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=vhci_hcd/8p, 5000M
My module is connected by usb Dual-q 5G2PHY… usb adapter.
Wait your kindly reply.
BR,
Luca
Sorry USB device is not recognized.
Could you take a photo of the device?
If the USB still cannot be recognized, then I think the solution is to log in to the module from the debug serial port.
OK. The RM551E connect with the Linux host over M.2 interface. Normally on the Linux side you should be able to see the USB device via lsusb.
But right now it is not recognized, I am not sure whether you have set the usbspeed or set the modem to PCIe EP mode. You might have to login in the modem over debug uart of the modem.
And then you can try to send the AT command over /dev/smd7.
Thank you for your kindly reply.
Let me clafify some points about what you want to do.
I’ve to connect my board with usb cable and connect tx/rx with my FTDI USB-COM adapter to tx-rx with serial connection with putty. It’s correct ? What are the serial parameter ? 9600,8,1,N ?
Yes. Maybe you would the quectel-id, please provide the Quectel-ID, and then I can send you the passwd.
You could login in the modem Linux shell.
Ciao. Luca / Paolo, se stai operando in ambiente linux con un terminale (minicom) avresti dovuto vedere qualcosa di simile
quindi postare id al moderatore…
Per curosità puoi DM dove l’hai comprato visto che costa solo 200?
Chiedo scusa a Bean per l’intrusione.
ALIBABA: negozio SHENZHEN HUASIFEI TECHNOLOGY CO. LTD.
Ok,grazie,ma sei riuscito ad avere il prompt nel terminale in uart_mode?
Se positivo manda i’id a Bean, altrimenti ritadri l’autenticazione per il rooting…egli ti sta dando una opportunità molto privilegiata!
Ti saluto
Please set the baudrate with 115200.
Here the output…
Quectel RM551 (X75-Snapdragon) and others X75-Snapdragon have OpenWrt built-in on the modem …
OpenWrt login: root
quectel-v : v2.0
Login info: S7dBzAnHIm7v+HYUZKAc80i1adxXHDcSmllKgrFzop9dmGe84skfhgElSzOSC5i/E+aTU7N3QiZwGPWhE9p0bGz8JnexvnWVeeS+4PnqDKH3n8gbZMO7+7R7wPIHMhExCipqEgFG4vToX/NUZMWAt/rg75rcZufnKZdo+lFoP//wITZwQQe6YENCeDhiJ7et18P1MgpQysTbPIcJWVBFOGr5qVnElphUgD6dB4SWXm0K9240AApVNaUBfJJrNIh1ismGA4OALgsmqYQ6zdoHDvBHzP8kXY0fZiHN/WjTfeAVZpJGQVsm9v+sfRZi/9bvkF88yBe4WTnhYAiMBKdP8g==
Hi Bean, can you provide details for next steps? Login credentials, commands to restore RM module ? Thank you for your kindly reply. BR
hello, please check this passcode, thanks~
Decryption Result:1faf6bd9bcb118f4
