I have IPPT enabled on the module, and the module is attached to my router via USB.
The router is configured for IPV6 passthrough, and devices on my network are receiving public IPV6 addresses.
Those devices are able to perform DNS resolution to public IPV6 addresses, but can’t ping those addresses.
The router itself is able to resolve IPV6 DNS resolutions and the router CAN ping those addresses.
For context, if I put the SIM back in the T-Mobile Home Internet modem that it came from, and connect that modem to the router, devices on the network receive public IPV6 addresses AND can ping public IPV6 addresses.
This limitation only happens when I’m using the RM521F-GL.
The router is using Asuswrt (latest Merlin).
Fact is, I don’t think it’s the router, since IPV6 passthrough works just fine with this router if I use the modem that T-Mobile provides.
With the RM521F-GL and IPV6 passthrough, IPV6 addresses are assigned to my network devices and those devices have IPV6 DNS resolution, but the RM521F-GL simply isn’t passing IPV6 traffic to anything except the router.
My MPDN rule is using the MAC address FF:FF:FF:FF:FF:FF to perform passthrough to the router; could that somehow be causing the problem?
I would have thought that enabling passthrough to the router would have enabled passthrough for everything connected to the router, but I am hardly an expert at this.
I’m using the rm501f and my openwrt router gets an unfiltered ipv6 ip, but none of my devices on the network do. I think tmobile sees the router differently then their gateway and isn’t handing out ipv6 ips the same.
I’m using a T-Mobile internet SIM in an M.2 to RJ45 Sled with a RM520N-GL. I’m connecting via ethernet to a Wifi Router (Ubiquiti Dream Machine, UDM) for my house. When I enable SLAAC, it creates an IPv6 Proxy to provide IPv6 address and routing for the rest of my network. This only works with the T-Mobile provided gateways (all of them), not the Quectel card. The UDM does get an IPv6 address and can ping from there out, but I can’t get the network behind it to work with it. I can help debug the differences between the two devices, but not knowledgeable enough in IPv6 SLAAC/DHCPv6 to know what is wrong.
T-Mobile IPv6:
SLAAC based, no DHCPv6-PD available.
Running NAT mode on the RM520, but IPPT also doesn’t work in the exact same way. (i.e. device on ethernet gets IPv6, devices behind router get IPv6, but no routes are available to work through router.)
Sorry, but tested how? Did you actually test with a T-Mobile internet SIM?
I am able to get a working IPv6 address and routing on a device connected via ethernet, but any attempts at using IPv6 Proxy with a UDM fails where it works with the T-Mobile gateway.
I wonder if this is a router problem. I had the same issue with a Mikrotik router.. It looks like the Quectel’s only provide addresses via SLAAC which has kind of a flaky implementation on my router. I wish Quectel would support DHCPv6 as I think it would probably fix a lot of problems for me. It’s already running dnsmasq so it might not be terrible to change the implementation to assign addresses via DHCPv6 instead. Once I configured IPv6 and IPPT and rebooted everything I was able to get a public IPv6 address and a default route. It worked for me on T-Mobile.
T-Mobile Home Internet USA ?
That is what I am using.
I didn’t think they serve IPV6.
Though, when I use Vee Pea eN clients on my various boxes, I can get an IPV6 address.
Something to do with DNS?
Oh, I am not using the modem in a router, I am using the Macuzone Ethernet adapter and have Simple Admin loaded into the modem.
I have IPPT configured in the modem.
I turned OFF the IPV4V6 DNS proxy in the modem.
I didn’t think [quote=“snowzach, post:15, topic:32304”]
[/quote]
@snowzach, I can configure IPPT, but what are you doing to configure IPv6 for t-mobile?
Honestly, I can get amazing speeds even with IPv4 only, but getting weird flaky behavior with dropped connections especially on long running connections (downloads have to keep retrying for example). Switch back to the Sagecomm device, and everything works smoothly but I’d rather run SA and an external antenna.
