thanks, @jfrog .
here is the result:
AT+QCFG=“CLAT”
+QCFG: “clat”,1,1,“”,0,“ipv4only.arpa.”,0,0,1,1,2,2
at+qmap=?
+QMAP: “WWAN”,(0,1),(1-42),<IP_family>,<IP_address>
+QMAP: “DMZ”,(0,1),(4,6),<IP_address>
+QMAP: “GRE”,(0,1),<IP_address>
+QMAP: “LAN”,<IP_address>
+QMAP: “LANIP”,<LAN_IP_start_address>,<LAN_IP_end_address>,<GW_IP_address>,
+QMAP: “MAC_bind”,(1-10),<MAC_address>,<IP_address>
+QMAP: “VLAN”,(2-255),(“enable”,“disable”),(1-3,11-13)
+QMAP: “MPDN_rule”,(0-3),(1-16),(0,2-255),(0-3),(0,1),<IPPT_info>
+QMAP: “IPPT_NAT”,(0,1)
+QMAP: “connect”,(0-3),(0,1)
+QMAP: “auto_connect”,(0-3),(0,1),(1-16)
+QMAP: “MPDN_status”
+QMAP: “AP_rule”,(0-3),(0-3)
+QMAP: “SFE”,(“enable”,“disable”)
+QMAP: “domain”,<domain_name>
+QMAP: “DHCPV4DNS”,(“enable”,“disable”)
+QMAP: “DHCPV6DNS”,(“enable”,“disable”)
+QMAP: “NAT_timeout”,(1-4,6),
I ran the ping and nslookup from the modem itself:
C:\Users\Administrator\Downloads\xadb>adb shell ping ipv4.tlund.se
- daemon not running. starting it now on port 5037 *
- daemon started successfully *
PING ipv4.tlund.se(2607:7700:0:1b:0:1:c10f:e4c3 (2607:7700:0:1b:0:1:c10f:e4c3)) 56 data bytes
64 bytes from 2607:7700:0:1b:0:1:c10f:e4c3 (2607:7700:0:1b:0:1:c10f:e4c3): icmp_seq=1 ttl=37 time=180 ms
64 bytes from 2607:7700:0:1b:0:1:c10f:e4c3 (2607:7700:0:1b:0:1:c10f:e4c3): icmp_seq=2 ttl=37 time=185 ms
64 bytes from 2607:7700:0:1b:0:1:c10f:e4c3 (2607:7700:0:1b:0:1:c10f:e4c3): icmp_seq=3 ttl=37 time=179 ms
64 bytes from 2607:7700:0:1b:0:1:c10f:e4c3 (2607:7700:0:1b:0:1:c10f:e4c3): icmp_seq=4 ttl=37 time=181 ms
64 bytes from 2607:7700:0:1b:0:1:c10f:e4c3 (2607:7700:0:1b:0:1:c10f:e4c3): icmp_seq=5 ttl=37 time=184 ms
64 bytes from 2607:7700:0:1b:0:1:c10f:e4c3 (2607:7700:0:1b:0:1:c10f:e4c3): icmp_seq=6 ttl=37 time=178 ms
64 bytes from 2607:7700:0:1b:0:1:c10f:e4c3 (2607:7700:0:1b:0:1:c10f:e4c3): icmp_seq=7 ttl=37 time=181 ms
64 bytes from 2607:7700:0:1b:0:1:c10f:e4c3 (2607:7700:0:1b:0:1:c10f:e4c3): icmp_seq=8 ttl=37 time=179 ms
64 bytes from 2607:7700:0:1b:0:1:c10f:e4c3 (2607:7700:0:1b:0:1:c10f:e4c3): icmp_seq=9 ttl=37 time=197 ms
64 bytes from 2607:7700:0:1b:0:1:c10f:e4c3 (2607:7700:0:1b:0:1:c10f:e4c3): icmp_seq=10 ttl=37 time=192 ms
64 bytes from 2607:7700:0:1b:0:1:c10f:e4c3 (2607:7700:0:1b:0:1:c10f:e4c3): icmp_seq=11 ttl=37 time=186 ms
64 bytes from 2607:7700:0:1b:0:1:c10f:e4c3 (2607:7700:0:1b:0:1:c10f:e4c3): icmp_seq=12 ttl=37 time=188 ms
^C
C:\Users\Administrator\Downloads\xadb>adb shell nslookup ipv4.tlund.se
Server: fd00:976a::9
Address: fd00:976a::9#53
Non-authoritative answer:
Address: 193.15.228.195
Address: 2607:7700:0:1b:0:1:c10f:e4c3
