RM520N-GL firmware version RM520NGLAAR03A03M4G_A0.301.A0.301
Dear @GL-AX3000
Sorry, we don’t familiar with this, please contact with manufacture of router.
Hello Quectel Support Team,
I am writing to request assistance regarding a Quectel RM520N (SDX65) module currently bricked.
The device is presently only accessible in Fastboot / EDL mode. The unit is not booting to normal operation, and AT command access is not available. Due to the current state, I am unable to extract firmware version or additional module details via software tools.
Kindly request your guidance on the following:
• Official recovery / unbrick procedure for RM520N (SDX65)
• EDL recovery method or recommended process to restore the module
• Recovery firmware package or signed programmer (if available)
This request is specifically to restore the hardware to a working state.
Thank you for your support and guidance.
Dear @m1mahesh
Do you try to upgrade the firmware again?
If want to try, share a picture of your RM520N.
Hello, good day. @silvia may I have the latest firmware for RM520N-GL please? Current version shown by AT+QGMR is RM520NGLAAR03A03M4G_01.201.01.201. Thank you.
Good day.
Is there any firmware update for Glinet GL-X3000-NR router?
I currently have version RM520NGLAAR03A03M4G.
Dear @q56ec2v6
Dear @GL-AX3000
Hi @silvia
Can I please receive a copy of the latest firmware for RM520N-GL. Current version:
ATI
  RM520N-GL
  Revision: RM520NGLAAR01A07M4G
AT+QGMR
  RM520NGLAAR01A07M4G_01.200.01.200
Hi @silvia
In this situation (Italy):
ATI
RM520N-GL
Revision: RM520NGLAAR03A03M4G
AT+QGMR
RM520NGLAAR03A03M4G_01.200.01.200
with big RSRP and SNR stability problems; same for 4 identical Quectel modules, in 4 different installation and 4 different geographical location.
Do you think can be firmware related ?
Many thanks
Dear @saddy
Dear @qmik
It is hard to say that related firmware or network environment.
I have sent firmware version to your email, please check.
Dear @silvia
You are very kind. Many thanks for firmware files.
Dear @silvia
please,
could you confirm if, after the upgrade to RM520NGLAAR03A03M4G_A0.303.A0.303,
a come back to RM520NGLAAR03A03M4G_01.200.01.200 would be still possible ?
Because the Quectel RM520N-GL are integrated in firewalls and I’m still waiting the firewall builder authorization. I would like to proceed with upgrade now, if you confirm that (in the worst case) I can come back to the RM520NGLAAR03A03M4G_01.200.01.200
Many thanks, Michele
Hi @silvia
forgive me, I have two questions regarding RM520N-GL:
a) after an upgrade, a downgrade from RM520NGLAAR03A03M4G_A0.303.A0.303 to RM520NGLAAR03A03M4G_01.200.01.200 is it possible ?
b) firmware downgrade/upgrade can be done also over-the-air (FOTA) ?
Many thanks
Hi @silvia
could you help me again for RM520N-GL ?
c) is there a PDF document that shows the firmware update procedures step-by-step for windows, linux and OTA ?
If answer to a) is YES, could you email me also the oldest RM520NGLAAR03A03M4G_01.200.01.200 ? Because, in the worst case, I will downgrade again before return the entire firewall to the supplier.
Many many thanks
Current firmware RM520NGLAAR03A03M4G_01.201.01.201
Can you please send me the latest firmware version
Thank you
Dear @qmik
a)It can downgrade to RM520NGLAAR03A03M4G_01.200.01.200.
b)It can upgrade/downgrade via OTA.
c)I will send the document and firmware to your email, please check later.
Dear @Jezz_Williams
Great @silvia
You’re very kind.
You sent me all the files I need, very helpful.
Because I can’t install Quectel linux tools using the firewall shell (due to the firewall linux OS limitation), is there a way also to backup QCN using OTA, before applying the firmware upgrade ?
Many many thanks, Michele
Dear @silvia
is there a way also to backup/restore QCN using OTA ?
tks, michele
