RM520N-GL Firmware, etc
I have resent it to you,pls check
Don’t worry Herbert the new version has the same problem, i will try with someone who has the file working properly.
i tried with 7z and winrar, same error, it says unexpected end of file error.
regards and thanks
@herbert.pan-Q Can i get the latest firmware for EM12-g and the rn520?
Thnaks
Please provide your detailed version
AT+QGMR
Can you provide a shared file storage system?
For the 2 EM12-G units
EM12GPAR01A21M4G_01.200.01.200
EM12GPAR01A21M4G_01.001.01.001
2 of many rm520
RM520NGLAAR01A05M4G_01.001.01.001
RM520NGLAAR01A08M4G_01.200.01.200
@herbert.pan-Q
I’ve said and tried many, many times, the file you gave me is corrupt! Can you share a new file?
I have tried with Windows file extract and WinZip but still FAILS!
See the Windows error as attached!
Hi Herbert,
I am using RM520N-GL modem.
ATI
RM520N-GL
Revision: RM520NGLAAR03A03M4G
I would like to receive the file below.
  • Latest Quectel_QConnectManager_Linux
  • Latest Quectel_Linux&Android_QMI_WWAN_Driver
  • Latest Quectel_Windows_USB_Driver(Q)_NDIS
  • Latest Firmware
My email address: grep94@naver.com
Thanks for your help.
Please could you send me the latest FW for Quectel RM520 (using the GL.iNet Spitz X-3000), to brosenz@gmail.com, thank you
Hello, same modem as logi, can I get the latest FW for RM520? my current version is RM520NGLAAR01A07M4G_01.201.01.201.
BTW, are R01 and R03 FW interchangeable?
Could you please send me the latest firmware, drivers and software (Win+Linux) for the module RM520NGLAA-M20-SGASA ?
Many thanks.
Please provide your current firmware version
AT+QGMR
@herbert.pan-Q, Hi, my RM520GL is currently running firmware revision RM520NGLAAR01A08M4G_01.202.01.202. Is this still the latest firmware in the R01 baseline? I’m asking because there are a couple of issues with it I’m hoping are fixed in a new FW. The R03 baseline does not preform well in my physical location compared to R01 so I cant use those.
You cannot perform to cross-baseline upgrades
@herbert.pan-Q , that explains why R03 does not preform then.
Is there a new R01 firmware at this time after RM520NGLAAR01A08M4G_01.202.01.202 you can provide?
Adam.
I have upgraded from RM520NGLAAR01A08M4G to RM520NGLAAR03A03M4G which was provided to me by ms silvia.
is it same baseline?
is performance different?
it is the latest firmware version
can you please share it with me too ? send private mesage for link please!
AT+QGMR
