RM520N-GL Firmware, etc
can you please share it with me too ? send private mesage for link please!
AT+QGMR
RM520NGLAAR01A08M4G_01.200.01.200
Please find it below:
RM520NGLAAR03A03M4G_01.200.01.200
Could you please provide me the latest revision?
Many Thanks!
@herbert.pan-Q
Can you please provide the latest firmware.
RM520NGLAAR03A03M4G_01.201.01.201
Also for the firmware can I use Qcom? Or is there another tool to use?
Could you please provide us the latest firmware, drivers and software (Win+Linux) for the module RM520NGLAA-M20-SGASA?
The current firmware revision is:
Thank you.
Yes, of course you can
I’ve already sent it to you, cross-baseline upgrades we generally don’t recommend
Can you please send me the most up to date firmware for the RM520N-GL? My current version is RM520NGLAAR01A08M4G_01.200.01.200. Can you also send the up to date windows flashing utility as well?
The file i was sent will not decompress, it may be corrupt. I have tried on windows 10 and 11.
hello, the file is corrupt. cannot decompress properly. used different tools and content of zip does not match to md5.txt… firehose folder completely missing
VERSION:1.0
FILE:START
FILE:\contents.xml:D1FEB4926F7087A17F5DB8897E2B4621
FILE:\update\abl.elf:B69A88EF0D08047FAE88ACF3A11DC70F
FILE:\update\aop.mbn:48F105C83DE28C3520F48A65DEAFF5D3
FILE:\update\apdp.mbn:F1F3959ABA6F90F4BEEFDC693C873748
FILE:\update\devcfg_low_ddr.mbn:68E12719EEDFB5FC57EA79985234B816
FILE:\update\devcfg.mbn:DC6B86AA96931B64F796D9F8B7513245
FILE:\update\firehose\partition_complete_p4K_b256K.mbn:39647C465AED1C4F6DCB01161F2244A0
FILE:\update\firehose\patch_p4K_b256K.xml:CFAD35AF13105B96A4FE21E92EC93967
FILE:\update\firehose\prog_firehose_lite.elf:DF1947F57E459591E954337F0D69C627
FILE:\update\firehose\rawprogram_nand_p4K_b256K_update.xml:E97BDD88337F766A24A39B1FC1AEBC17
FILE:\update\hyp.mbn:700D2935BA885FB4148492B84FEBBFC2
FILE:\update\ipa_fws.elf:F8C6B926E6971815A382FDCAFB96A9D7
FILE:\update\logfs_ufs_8mb.bin:C040A889D66A4F120F502F89B551F42B
FILE:\update\multi_image.mbn:53717FA61F71D3E1624EDFC54DC6E0E7
FILE:\update\multi_image_qti.mbn:78E9905AD8019994092DC3EBAD15D352
FILE:\update\NON-HLOS.ubi:C0765514BD6CB952A0235EDB8F78DDA7
FILE:\update\oemapp.ubi:4B6E110DF33EB55D9213D1B9EC48E698
FILE:\update\oemdata.ubi:4BFE3CD83DF81DEA2EB3B9E2908493C5
FILE:\update\partition.mbn:881467DFEFB52466A30D3B2FD46D1BB5
FILE:\update\partition_nand.xml:C5584F78FB696CEECD8DB8E76B85F927
FILE:\update\sdxlemur-boot.img:9AFEC9AB8D6F81F99AE9C465734E635C
FILE:\update\sdxlemur-recoveryfs.ubi:0FB05F7A1C5109B37CA719A62C3E37F3
FILE:\update\sdxlemur-sysfs.ubi:21B1CA6BEAE2072B4FC73C4817D5A076
FILE:\update\tz.mbn:18F7A854E3ACA0CB9AAAB0D0EFAA911E
FILE:\update\uefi.elf:409397A3A3155B9D267FF5C0589F6CD2
FILE:\update\usrdata.ubi:A3E687DECD4A3A32FEF6EC8B9EBCC305
FILE:\update\xbl_config.elf:0129D5834946C120FDCCF23238D125D9
FILE:\update\xbl.elf:7A253830D8E5C30FAAD48FAD8E2AB1EC
FILE:\update\xbl_ramdump.elf:8466B5D840C3C1B2CDD4D8CAD0BEDF19
FILE:\upgrade\targetfiles.zip:CB539F1CAD6EFA9B73DA18B22B09D9EB
FILE:END
@herbert.pan-Q Thank you for your support!
Hi @herbert.pan-Q ,
I got the latest firmware from you as well as the latest qflash v7.0. The upgrade was close to succeed but failed on DM port time out. The DM port seems to be removed right after starting the download process. Please see the image.
Can you please help?
you can try pull up the BOOT pin to force update
Hi @herbert.pan-Q ,
The dev-board is ‘5G M.2 To USB3.0-KIT Pro V2.0’. I don’t see any pins available (I also removed the module and checked underneath). Anything else I can do to force update?
