I have sent them to your email,pls check
Good day!
Please advise if a firmware update is available:
ATI
RM520N-GL
Revision: RM520NGLAAR01A07M4G
If a newer firmware is available, please send me the latest firmware and the tool to flash the firmware, for Windows 10.
Thank you!
Hello @herbert.pan-Q
I am still experiencing issues downloading the firmware file for the RM520N-GL, could you please resend the link with adjusted permissions?
Thanks! I’ve received the tools and fw.
But I have a question - is this fw RM520NGLAAR03A01M4G_01.202.01.202 compatible with RM520N-GLAP module (not GLAA)?
My module is GLAP (with fixed pcie mode).
Thanks again!
Sorry, I can’t find this firmware model
May be you can find this version of FW?
ATI
ATI
RM520N-GL
Revision: RM520NGLAPR01A03M4G
Thanks!
no,no,I can’t find this firmware
Sad( But thanks for your efforts
I also need the latest Quectel_Linux_PCIE_MHI_Driver and if there is a PCIE MHI Driver for windows, I need that as well.
Thank you.
Is there an updated manual? I’m trying AT+QMAPWAC=1 to make AP auto dial and it doesn’t work.
Before updating it gave an error, now it gives ok, but it seems to do nothing. I use an m.2 to rj45 adapter but I can’t get it to work autonomously, without the need to start it via usb debug every time I turn it on.
Hi @herbert.pan-Q can you send me actual versions of these tools?
Linux Serial USB driver: Quectel_Linux_USB_Serial_Option_Driver
Quectel-CM Tool: Quectel_QConnectManager_Linux
QLog Tool: QLog_Linux_Android
Linux QMI_WWAN driver: Quectel_Linux&Android_QMI_WWAN_Driver
Linux MHI driver: Quectel_Linux_PCIE_MHI_Driver
Thanks!
Please send me the latest firmware and flashing tool for RM520N-GL.
Below is my current version:
RM520N-GL
Thank you!
I am using my quectel module with openairinterface following this tutorial:
I understand the model specified is not the RM520N-GL, but it does work with the setup.
I notice that it states the windows driver must be later than 2.4.6, and I received v2.3.3. Is there a later, most up to date version of the windows driver you can send me please?
Hi All,
@herbert.pan-Q please send me the link to the latest FW/update available. (IceClubber@wp.pl)
Is there any documentation on how to properly connect the antennas?
