RM502Q-AE stuck in FTM mode after firmware upgrade
RM502Q-AE flashed with QFlash_V6.4, “RM502QAEAAR13A02M4G” image, now it’s stuck in Factory Test Mode.
CFUN returns 5
Probably missing QCN data.
Please help
Dear @victors
As you know, every module has different parameters, if you restore the QCN which from my module, I am not sure if your module has any unexpected problem. Because when every module will do calibration before shipping.
But if you don’t care this, I can share a QCN to you.
I flashed it with QFlash, but I think I used the wrong file, “partition_complete_p4K_b256K.mbn”
So now it’s stuck in FTM. Is there any other way to fix it?
Dear @victors
The other way is return back to your provider for restore, I am not sure whether your provider will accept.
if you ship it to me, the freight also is expensive.
OK, let me try the QCN file then. I do have QPST_2.7.496 program.
Dear @victors
I have sent QCN and user guide to you via Message, please check.
I realize this topic was last active a while ago but I made the same mistake with my RM520N-GL. Can I have the file and recovery instructions too? Thanks in advance.
Dear @Navegador
Please note after restore the QCN from my file, the performance will be worse than before.
Dear @silvia
can you please provide QCN and Guide for RG502Q-AE? Having the similar problem as the original author. thank you in advance
Dear @spolack
Dear @silvia
Can you please provide QCN and Guide for RM502N-EU? Having the similar problem as the original author. thank you in advance
Dear @Canhcanh
Sorry, I didn’t find RM502Q-EU, please check again.
(post deleted by author)
RM520N-EU
Revision: RM520NEUDAR03A09M4G
+CFUN: 7
Dear @Canhcanh
Execute AT+CFUN=1 show error, right?
Restore my QCN, the performance will be worse, do you accept?
Thanks in advance. I tried it but still got the error: AT+CFUN=7
Dear @Canhcanh
If yes, I will share QCN later.
Dear @silvia
My module RM502Q-AE, Revision RM502QAEAAR11A02M4G was bricked during firmware upgrade, then recovered successfully with QFlash, but now it reports AT+CFUN? = 5 and cannot register to network.
Could you please provide me with the QCN file, the required recovery tool, and the instructions to restore my RM502Q-AE module :smiling_face_with_tear: ?
Please send any available files and guidance to my email: s2ofthewind@gmail.com
Thank you.
Best regards,
Dear @Quyen_D_ng_Ng_c
