Sorry, I cannot validate mbim tools operation on my side at the moment.
But please show the output of cat /etc/mbim-network.conf
my bad the APN spelling was wrong ![]()
pi@RevPi45698:~ $ sudo cat /etc/mbim-network.conf
APM=internet
APN_USER=ipa
APN_PASS=xxxxx
APN_AUTH=PAP
PROXY=yes
I entered the above details in the .conf file and again ran the mbim-network start, set ip script and then ping. The connection was setup I could get the ping. I stopped the ping and tried ping command again and it gave the same error: network is unreachable.
Now mbim-network start command has this output:
root@RevPi45698:/home/pi# mbim-network /dev/cdc-wdm0 start
/usr/bin/mbim-network: 138: /usr/bin/mbim-network: [[: not found
Loading profile at /etc/mbim-network.conf…
APN: internet
APN auth protocol: PAP
APN user: ipa
APN password: xxxxxx
mbim-proxy: yes
Loading previous state from /tmp/mbim-network-state-cdc-wdm0…
Previous Transaction ID: 8
error: no actions specified
Clearing state at /tmp/mbim-network-state-cdc-wdm0…
Querying subscriber ready status ‘mbimcli -d /dev/cdc-wdm0 --query-subscriber-ready-status --no-close --device-open-proxy’…
[/dev/cdc-wdm0] Subscriber ready status retrieved: Ready state: ‘initialized’ Subscriber ID: ‘999400000256440’ SIM ICCID: ‘8900099100002144403F’ Ready info: ‘none’ Telephone numbers: (0) ‘unknown’ [/dev/cdc-wdm0] Session not closed: TRID: ‘4’
Saving state at /tmp/mbim-network-state-cdc-wdm0… (TRID: 4)
Querying registration state ‘mbimcli -d /dev/cdc-wdm0 --query-registration-state --no-open=4 --no-close --device-open-proxy’…
[/dev/cdc-wdm0] Registration status: Network error: ‘unknown’ Register state: ‘home’ Register mode: ‘automatic’ Available data classes: ‘custom’ Current cellular class: ‘gsm’ Provider ID: ‘99940’ Provider name: ‘DA’ Roaming text: ‘unknown’ Registration flags: ‘packet-service-automatic-attach’ [/dev/cdc-wdm0] Session not closed: TRID: ‘6’
Saving state at /tmp/mbim-network-state-cdc-wdm0… (TRID: 6)
Attaching to packet service with ‘mbimcli -d /dev/cdc-wdm0 --attach-packet-service --no-open=6 --no-close --device-open-proxy’…
Saving state at /tmp/mbim-network-state-cdc-wdm0… (TRID: 8)
Starting network with ‘mbimcli -d /dev/cdc-wdm0 --connect=apn=’‘,auth=‘PAP’,username=‘ipa’,password=‘xxxxx’ --no-open=8 --no-close --device-open-proxy’…
Do you have the same with “APN” corrected ?
this is the current output with “APN” corrected
root@RevPi45698:/home/pi# ping 8.8.8.8
connect: Network is unreachable
root@RevPi45698:/home/pi# mbim-network /dev/cdc-wdm0 status
APN: internet
APN user: ipa
APN password: fffffff
mbim-proxy: yes
Getting status with ‘mbimcli -d /dev/cdc-wdm0 --query-connection-state --device-open-proxy’…
Status: deactivated
APN: internet
APN user: ipa
APN password: zzzzz
mbim-proxy: yes
Starting network with ‘mbimcli -d /dev/cdc-wdm0 --connect=apn=‘internet’,auth=‘PAP’,username=‘ipa’,password=‘xxxxx’ --no-open=8 --no-close --device-open-proxy’…
error: couldn’t get IP configuration response message: Transaction timed out
Network start failed
[/dev/cdc-wdm0] Successfully connected [/dev/cdc-wdm0] Connection status: Session ID: ‘0’ Activation state: ‘activated’ Voice call state: ‘none’ IP type: ‘ipv4’ Context type: ‘internet’ Network error: ‘unknown’ [/dev/cdc-wdm0] Session not closed: TRID: ‘11’
Saving state at /tmp/mbim-network-state-cdc-wdm0… (TRID: 11)
root@RevPi45698:/home/pi# cd Documents
root@RevPi45698:/home/pi/Documents# ./mbim-set-ip.sh /dev/cdc-wdm0 wwan0
Requesting IPv4 and IPv6 information through mbimcli proxy:
error: couldn’t get IP configuration response message: ContextNotActivated
Applying the following network interface configurations:
ip link set wwan0 down
ip addr flush dev wwan0
ip -6 addr flush dev wwan0
ip link set wwan0 up
Network interface configurations completed.
root@RevPi45698:/home/pi/Documents# ping 8.8.8.8
Once mbim-network is completed run
mbimcli -d /dev/cdc-wdm0 -p --query-ip-configuration
and nothing else.
Try to repeat the command as shown here, use your current transaction ID.
APN: internet
APN user: ipa
APN password: XXXX
mbim-proxy: yes
Previous Transaction ID: 11
Network started successfully
root@RevPi45698:/home/pi# mbimcli -d /dev/cdc-wdm0 -p --query-ip-configuration
[/dev/cdc-wdm0] IPv4 configuration available: ‘address, gateway, dns, mtu’
IP [0]: ‘192.168.241.5/30’
Gateway: ‘192.168.241.6’
DNS [0]: ‘8.8.8.8’
DNS [1]: ‘8.8.4.4’
MTU: ‘1452’
[/dev/cdc-wdm0] IPv6 configuration available: ‘none’
Great, but you’re trying to ping too early. You now see that the modem has something from the carrier, but this information is local to the modem. You need to configure your interface like wwan0, set the default route and only after all of these you can try ping. My understanding that mbim-set-ip.sh supposed to do exactly this - pull the information from the modem and apply it to the interface.
Next time you can try running the script like this:
bash -x mbim-set-ip.sh {required arguments}
and see if there are any errors.
these are the errors
root@RevPi45698:/home/pi# bash -x ./mbim-set-ip.sh /dev/cdc-wdm0 wwan0
bash: ./mbim-set-ip.sh: No such file or directory
root@RevPi45698:/home/pi/Documents# bash -x ./mbim-set-ip.sh /dev/cdc-wdm0 wwan
- ipv4_addresses=()
- ipv4_gateway=
- ipv4_dns=()
- ipv4_mtu=
- ipv6_addresses=()
- ipv6_gateway=
- ipv6_dns=()
- ipv6_mtu=
- CONTROLDEV=/dev/cdc-wdm0
- DEV=wwan0
- echo ‘Requesting IPv4 and IPv6 information through mbimcli proxy:’
Requesting IPv4 and IPv6 information through mbimcli proxy: - mbimcli -d /dev/cdc-wdm0 -p --query-ip-configuration
++ mbimcli -d /dev/cdc-wdm0 -p --query-ip-configuration=0
error: couldn’t get IP configuration response message: ContextNotActivated - IPDATA=
- read -r line
- ‘[’ -z ‘’ ‘]’
- continue
- read -r line
- [[ -n ‘’ ]]
++ mktemp - execfile=/tmp/tmp.D5FBYqfWhX
- printf ‘ip link set wwan0 down\n’
- printf ‘ip addr flush dev wwan0 \n’
- printf ‘ip -6 addr flush dev wwan0 \n’
- printf ‘ip link set wwan0 up\n’
- [[ 0 > 0 ]]
- [[ 0 > 0 ]]
- echo ‘Applying the following network interface configurations:’
Applying the following network interface configurations: - cat /tmp/tmp.D5FBYqfWhX
ip link set wwan0 up - bash /tmp/tmp.D5FBYqfWhX
- rm /tmp/tmp.D5FBYqfWhX
- echo ‘Network interface configurations completed.’
root@RevPi45698:/home/pi/Documents# mbim-network /dev/cdc-wdm0 start
APN: internet
APN user: ipa
APN password: vfk4ever
mbim-proxy: yes
error: couldn’t open the MbimDevice: Transaction timed out
Querying registration state ‘mbimcli -d /dev/cdc-wdm0 --query-registration-state --no-open= --no-close --device-open-proxy’…
error: invalid transaction ID specified:
Attaching to packet service with ‘mbimcli -d /dev/cdc-wdm0 --attach-packet-service --no-open= --no-close --device-open-proxy’…
Starting network with ‘mbimcli -d /dev/cdc-wdm0 --connect=apn=‘internet’,auth=‘PAP’,username=‘ipa’,password=‘vfk4ever’ --no-open= --no-close --device-open-proxy’…
any help would be really appreciated
No improvements. I think these could be posibile issues/solutions:
- can updating the kernel version help in any way?
if yes, can you please give me detailed steps to update the kernel?
OR maybe I can reset the modem completely and then repeat the process of adding and loading the driver?
ALSO, when the RevPi boots up, I get this message in the boot logs
[FAILED] Failed to start dhcpcd on all interfaces
I do not see any issue with the modem or OS. The problem is probably with mbim-set-ip.sh script.
You have the connection established and IP information obtained:
All you need is to configure an interface with the data obtained from the nodem.
There is an example here, look for
- After the network started, one can query current IP configuration like this:
I have got it working now finally!
The issue was with my 5G network and then the Firewall was blocking the ports.
Thank you so much for your help throughout.
can you please give more details on how you fixed it? I am also having some issues to connect to the OAI 5G SA with my Quectel modem. The device seems to register to the network as the MBIM GUI shows, but I am not able to get an IP and connect to the internet.
Any help would be appreciated
