RIL Library not provided by quectel
We Added RIL library provided by the quectel team to our Android 9.0 and we compiled.
Then we checked whether library is loaded or not, with command given in user guide.
It is loaded according to document.
Then we checked version of library loaded, but it is printing nothing.(According to document if nothing prints, then library not given by quectel team)
Can you suggest me how to overcome this problem.
RIL Library loaded
iwg34m_8mm:/ # cat /init*.rc | grep ril-daemon
service ril-daemon /vendor/bin/hw/rild -l /vendor/lib64/libreference-ril.so
Version of RIL library
iwg34m_8mm:/ # getprop gsm.version.ril-impl
iwg34m_8mm:/ #
iwg34m_8mm:/ #
Do you get any reault by using
getprop | grep ril
Did you set:
vendor.rild.libargs
vendor.rild.libpath
You should have some similar to:
Thank you for your valuable support.
I din't get such a result if i am using below command.
iwg34m_8mm:/ # getprop | grep ril
[init.svc.ril-daemon]: [running]
[init.svc.vendor.ril-daemon]: [running]
[ro.boottime.ril-daemon]: [9507228625]
[ro.boottime.vendor.ril-daemon]: [9686903375]
[ro.radio.noril]: [yes]
[ro.ril.wake_lock_timeout]: [300]
iwg34m_8mm:/ #
iwg34m_8mm:/ #
iwg34m_8mm:/ #
iwg34m_8mm:/ # getprop | grep gsm
[gsm.current.phone-type]: [1]
[gsm.network.type]: [Unknown]
[gsm.operator.alpha]: []
[gsm.operator.iso-country]: []
[gsm.operator.isroaming]: [false]
[gsm.operator.numeric]: []
Can you suggest me how to set below two things:
vendor.rild.libargs
vendor.rild.libpath
Thank You,
Regards,
Sudarshan
it depends on your Build Structure, you need to add multiple Parameters.
lemme show your my way to do it:
i placed all my stuff in /vendor/quectel/ec25
vendor/quectel/ec25$ cat BoardConfigPartial.mk
BUILD_WITH_EC25 := true
BOARD_HAS_GPS := true
BOARD_HAVE_DONGLE := true
vendor/quectel/ec25$ cat device-partial.mk
ifeq ($(BUILD_WITH_EC25),true)
PRODUCT_PACKAGES += \
       rild \
## check if needed
PRODUCT_COPY_FILES += \
        vendor/quectel/ec25/ril/libreference-ril.so:vendor/lib64/libquectel-ril.so \
        vendor/quectel/ec25/ril/ql-ril.conf:system/etc/ql-ril.conf \
        vendor/quectel/ec25/ril/chat:system/bin/chat \
        vendor/quectel/ec25/tools/QAndroidLog:system/bin/QAndroidLog \
        vendor/quectel/ec25/tools/QFirehose:system/bin/QFirehose \
        vendor/quectel/ec25/ril/ip-up:system/etc/ppp/ip-up \
        vendor/quectel/ec25/ril/ip-down:system/etc/ppp/ip-down \
        vendor/quectel/ec25/ril/atinout:system/bin/atinout \
        vendor/quectel/ec25/apns-conf.xml:system/etc/apns-conf.xml \
        frameworks/native/data/etc/android.hardware.telephony.cdma.xml:$(TARGET_COPY_OUT_VENDOR)/etc/permissions/android.hardware.telephony.cdma.xml \
        frameworks/native/data/etc/android.hardware.telephony.gsm.xml:$(TARGET_COPY_OUT_VENDOR)/etc/permissions/android.hardware.telephony.gsm.xml \
        frameworks/native/data/etc/android.software.sip.voip.xml:$(TARGET_COPY_OUT_VENDOR)/etc/permissions/android.software.sip.voip.xml \
        frameworks/native/data/etc/handheld_core_hardware.xml:$(TARGET_COPY_OUT_VENDOR)/etc/permissions/handheld_core_hardware.xml \
        frameworks/native/data/etc/android.hardware.audio.low_latency.xml:$(TARGET_COPY_OUT_VENDOR)/etc/permissions/android.hardware.audio.low_latency.xml
# RILD Related
PRODUCT_PROPERTY_OVERRIDES += \
        hw.nophone=no \
        ro.boot.noril=no \
        ro.radio.noril=no \
        ro.telephony.default_network=10 \
        vendor.rild.libpath=/vendor/lib64/libquectel-ril.so \
        vendor.rild.libargs=-d/dev/ttyUSB2 \
        keyguard.no_require_sim=true \
        ril.function.dataonly=0
#       ril.subscription.types=NV,RUIM \
# Phone Related
        persist.telephony.support.ipv6=1 \
        persists.telephony.support.ipv4=1 \
        telephony.lteOnGsmDevice=1 \
        telephony.lteOnCdmaDevice=0 \
        ro.telephony.call_ring.delay=0 \
        ro.ril.enable.amr.wideband=1 \
        ring.delay=0 \
        ro.config.vc_call_steps=20 \
        persist.cust.tel.eons=1 \
        ro.config.hw_fast_dormancy=1 \
        ro.radio.networkmode=enable \
        persist.audio.fluence.voicecall=false
        ro.HOME_APP_ADJ=1 \
        persist.sys.use_dithering=1 \
        ro.config.nocheckin=1 \
        persist.adb.tcp.port=5555 \
        hw.nobattery=true \
        ro.com.android.dataroaming=false
        ro.telephony.get_imsi_from_sim=true \
        ro.telephony.ril.config=simactivation
endif ### BUILD_WITH_EC25 ###
ifeq ($(BOARD_HAS_GPS),true)
        android.hardware.gnss@1.0-impl \
        android.hardware.gnss@1.0-service
        vendor/quectel/ec25/gps/gps.default.so:vendor/lib64/hw/gps.default.so \
        vendor/quectel/ec25/gps/gps_cfg.inf:system/etc/gps_cfg.inf \
        vendor/quectel/ec25/gps/gps.cfg:system/etc/gps.cfg \
        frameworks/native/data/etc/android.hardware.location.xml:$(TARGET_COPY_OUT_VENDOR)/etc/permissions/android.hardware.location.xml \
        frameworks/native/data/etc/android.hardware.location.gps.xml:$(TARGET_COPY_OUT_VENDOR)/etc/permissions/android.hardware.location.gps.xml
    ro.kernel.android.gps=ttyUSB1 \
    ro.kernel.android.gps.speed=115200 \
    ro.kernel.android.gps.max_rate=1
endif ### BUILD_WITH_EC25_GPS ###
in your BoardConfig.mk
-include vendor/quectel/ec25/BoardConfigPartial.mk
in your device.mk
$(call inherit-product-if-exists, vendor/quectel/ec25/device-partial.mk)
        $(LOCAL_PATH)/init.quectel.rc:root/init.quectel.rc
    endif
in your init.device.rc
import init.quectel.rc
init.quectel.rc make shure you comment all other rild due duplicates
service vendor.ril-daemon /vendor/bin/hw/rild -l /vendor/lib64/libquectel-ril.so
    class main
    user root
    group radio vpn cache inet misc audio log readproc wakelock
    capabilities BLOCK_SUSPEND NET_ADMIN NET_RAW
# hardware/interfaces/gnss/1.0/default/android.hardware.gnss@1.0-service.rc
service gnss_service /vendor/bin/hw/android.hardware.gnss@1.0-service
    class hal
    user gps
    group system gps radio
in your manifest.xml
    <hal format="hidl">
        <name>android.hardware.broadcastradio</name>
        <transport>hwbinder</transport>
        <version>1.0</version>
        <interface>
            <name>IBroadcastRadioFactory</name>
            <instance>default</instance>
        </interface>
    </hal>
    <hal format="hidl">
        <name>android.hardware.radio.deprecated</name>
        <interface>
            <name>IOemHook</name>
            <instance>slot1</instance>
        </interface>
    </hal>
    <hal format="hidl">
        <name>android.hardware.radio</name>
        <version>1.1</version>
        <interface>
            <name>IRadio</name>
        </interface>
        <interface>
            <name>ISap</name>
        </interface>
    </hal>
Regards,
Brian
Thank you for valuable support.
I did the changes as your instruction, and it is worked for me.
I did the changes as your instruction and it is worked for me.
  1. We tested call feature with quectel 4G module.
    We are able to call and able to receive the call but not audible.
    Can you suggest me the implementation procedure for voice over a USB.
  2. Also, we are interested to test GPS in android with Quectel 4G module.
    Can you please share the GPS related libraries and implementation procedure.
Thank You,
Regards,
Sudarshan
Hi Sudarshan,
for GPS you need to add GNSS HAL to manifest.xml
 <hal format="hidl">
        <name>android.hardware.gnss</name>
        <interface>
            <name>IGnss</name>
        </interface>
    </hal>
the rest is already attached above and you should be good to go
make shure gps.default.so in Folder as shown above and in gps_cfg.inf use
NMEA_PORT_PATH=rild-nmea
you should receive GPS Info via cat /dev/ttyUSB1 as defined above and during rild-nmea in GPS Tracker
For USB Audio Routing/Mixing/UAC in Android i´m in the same situation as you are.
i´m still waiting for Feedback from Quectel since to point only to EVB kit Audio HW without sample under Android is kinda useless.
As requested here EC25 LTE Voice Audio | Android 9.x
At least you should check the USB AUDIO UAC Manual to enable Audio Device as Card(N) under
rk3399:/proc/asound # ls -la
total 0
dr-xr-xr-x   5 root root 0 2020-07-23 12:43 .
dr-xr-xr-x 276 root root 0 1970-01-01 01:00 ..
lrwxrwxrwx   1 root root 5 2020-07-23 12:43 Android -> card2
and
rk3399:/dev/snd # ls -la
total 0
drwxr-xr-x  2 root   root       220 2020-07-12 16:59 .
drwxr-xr-x 19 root   root      1840 2020-07-12 16:59 ..
crw-rw----  1 system audio 116,   7 2020-07-12 16:59 controlC2
crw-rw----  1 system audio 116,   9 2020-07-12 16:59 pcmC2D0c
crw-rw----  1 system audio 116,   8 2020-07-12 16:59 pcmC2D0p
crw-rw----  1 system audio 116,  33 2020-07-12 16:59 timer
shown here as Control2 / pcmC2D0c / pcmC2D0p devices.
Device ID´s can be different due multiple Audio Devices depending on your Board.
Regards,
Brian
Can you please share the below 3 files related to GPS.
1.gps.default.so
2.gps_cfg.inf
3.gps.cfg
Thank You,
Regards,
Sudarshan
i´ve attached the files to
gps.default.so is arm64-v8a
Regards,
Brian
We added the changes for GSM as you instructed, but in boot log we are getting below prints continuously.
And GSM not working.
[ 77.493455] init: starting service ‘vendor.gnss_service’…
[ 77.539830] init: Service ‘vendor.gnss_service’ (pid 3267) exited with status 1
[ 77.547188] init: Sending signal 9 to service ‘vendor.gnss_service’ (pid 3267) process group…
[ 77.556045] libprocessgroup: Successfully killed process cgroup uid 1021 pid 3267 in 0ms
[ 82.157049] init: starting service ‘gnss_service’…
[ 82.500369] init: starting service ‘vendor.gnss_service’…
[ 82.609871] init: Service ‘gnss_service’ (pid 3272) exited with status 1
[ 82.617303] init: Sending signal 9 to service ‘gnss_service’ (pid 3272) process group…
[ 82.625684] libprocessgroup: Successfully killed process cgroup uid 1021 pid 3272 in 0ms
[ 82.634232] init: Service ‘vendor.gnss_service’ (pid 3277) exited with status 1
[ 82.641661] init: Sending signal 9 to service ‘vendor.gnss_service’ (pid 3277) process group…
[ 82.650666] libprocessgroup: Successfully killed process cgroup uid 1021 pid 3277 in 0ms
Can you suggest me to over come this problem.
Thank you,
Regards,
Sudarshan.
Wait GNSS service starts twice
and
‘gnss_service’
So somewhere you have duplicate entry, besides this what did you changed also due gsm was working before.
Rgds,
Brian
We did the changes as your instruction for testing GPS in android.
In boot log if we enter below command it will show like,
iwg34m_8mm:/ # getprop | grep gps
[persist.sys.gps.lpp]: [0]
[ro.kernel.android.gps]: [ttyUSB1]
[ro.kernel.android.gps.max_rate]: [1]
[ro.kernel.android.gps.speed]: [115200]
iwg34m_8mm:/ #
iwg34m_8mm:/ #
iwg34m_8mm:/ #
iwg34m_8mm:/ # getprop | grep gnss
[init.svc.gnss_service]: [running]
[init.svc.vendor.gnss_service]: [running]
[ro.boottime.gnss_service]: [11865840875]
[ro.boottime.vendor.gnss_service]: [12452596500]
  1. Whether same result you observed as above.? if not share your above two command prints?
  2. Can you please share me how you test GPS in android.?
  3. For EC25 quectel module which GPS antenna you are connected(part number)?
We tested with google map and GPS TEST v1.5.4.APK file, but we din’t get the expected behavior.
Thank you,
Regards,
Sudarshan
For my project i´m using this this GPS Antenna:
and that LTE Antenna:
the Android properties:
rk3399:/ # getprop | grep gps
rk3399:/ # getprop | grep gnss
[ro.boottime.vendor.gnss_service]: [6167597595]
rk3399:/ #
comment or remove 2nd gnss_service in init.quectel.rc (commented it in my latest code) since it is called in
rk3399:/ # cat init.quectel.rc
# hardware/ril/rild/rild.rc
    class main
    user root
#service gnss_service /vendor/bin/hw/android.hardware.gnss@1.0-service
#    class hal
#    user gps
#    group system gps radio
rk3399:/ #
for fixing you should check GPS Accuracy
We aslo tested GPS, for us it is working.
Now we are testing voice over USB with AT command.
We are able to call and receive the call with AT command, but it is not audible.
  1. Have you tested voice over a USB with AT command.?
  2. If you are tested, Can you please share the changes.?
Thank You,
Regards,
Sudarshan
As i’ve already told you above that i’m also stuck at this point. I’m not related to quectel in any form and waiting also for reply from them.
Regards,
Brian
One more question related to GPS.
Are you able to find the location with Google map?
For me with GPS TEST v1.5.4.APK file i am able to find the location, but with google map i am not able to find the location.
Thank You,
Regards,
Sudarshan
Post your code for gps implementation and I’ll look into it.
Rgds,
Brian
Kindly check the attached GPS.png.
file.
Thank you,
Regards,
Sudarshan
what bout that stuff
frameworks/native/data/etc/android.hardware.location.xml:$(TARGET_COPY_OUT_VENDOR)/etc/permissions/android.hardware.location.xml \ frameworks/native/data/etc/android.hardware.location.gps.xml:$(TARGET_COPY_OUT_VENDOR)/etc/permissions/android.hardware.location.gps.xml
and
and so on…
Can you please recheck the below changes once.(Related to GPS)
with the below changes also i am not able to get the location in google map.(We are testing google map in browser not in GoogleMap Android application.)
Thank you,
Regards,
Sudarshan
