Hello Quectel Team,
I’m currently working with the “FCM362K” BLE + Wi-Fi module in a UART-controlled embedded system and am looking for the official AT command manual and reference documentation specific to this module.
I’ve searched across the Quectel documentation portal and forums, but I couldn’t find a dedicated AT command manual or application guide for the FCM362K. Most of the references available seem to be for the “FCM360W” module.
I would appreciate it if you could kindly clarify the following:
- Is the FCM362K fully compatible with the FCM360W’s AT command set?
- If there are any differences in supported features, command sequences, or initialization flows, could you please highlight them?
- Could you please share the official AT command manual and hardware reference manual for FCM362K, if available?
This information is critical for correct integration in our UART-based stack for BLE GATT and Wi-Fi client functionality.
If any users here have already obtained these documents or tested FCM362K with AT command flows, I’d appreciate your help and guidance as well.
Thank you in advance!
Best regards,
Prajwal Kr
