Hello. How can I fix the modem broken RM502Q-GL? It is visible in the system as 9008. When trying to firmware, it is disabled because it restarts every 15 seconds. Help me, please.
Once I solved with the pin 65 to ground…but I do not guarantee the same results.
Howdy! I had posted here at a b c ;still waiting , in the end I solved with a lot of reading and countless tests. I was able to do this because a possible modem corruption would not have resulted in significant economic damage.The usb_boot method undocumented using test pins was not successful:“USB_BOOT” to 1.8 V before “VDD_EXT” is powered on connect the two pins before power on module, then after the QDloader port appeared, please disconnect”, in fact, it brought the modem into an unstable situ…
https://forums.quectel.com/uploads/short-url/8ooVDjYgZFup15iGQALFZCSTewK.jpeg
Hello, I tryed to post recently this matter:
recently purchased a second hand modem, but it not works, in w10 give me only 2 ports, one unavailable DM_com port and a ready Nmea_port ,so if disable driver it appear as ECM device; so I put it into usb_boot by bridge vreg & usb_boot test pins and use Qflash:5.8 but it hangs on download_raw and go in timeout.After the card still remain in QDLoader by removing the bridge as unique com port and is recognized as QUSB_BULK_CID:0410_SN:49CBD7EF in a fre…
https://forums.quectel.com/t/re-latest-firmware-for-rm502q-gl/31585
silvia
September 10, 2024, 1:39am
3
Dear @Stanislav_Potapov
What is your problem? Your module can’t power on or others.
You can try to contact USB_boot to 1.8V and try if module restart or not.
The USB_boot pin is in the rear of module, I have sent the picture for reference via Message, please check.
If module doesn’t restart, you can try to upgrade again.
Hello Silvia,
After what I think was a mistake, the module restarted but is no longer visible at all (no ports are recognized) under Linux and Windows.
Could you please help me?
Thank you.
Dear @tidusff1062
What did you operate before?
