I have the problem with the network registration of my Wislink2011 from Rakwireless. My SIM card is from Vodafone Australia. The module and SIM card information are still shown in the QNavigator software. I still can use GPS function. Please help me with this issue. Thank you for reading
thanks, I have used the following command:
AT+CGDCONT=1,“IP”,“spe.inetd.vodafone.nbiot”
And then, I reset the module, still “not registered” or “registration failed”.
Here’s are the AT commands and returns:
/* Use AT+CREG? /AT+CGREG? to query the network registration status. */
[2022-11-05 10:53:28:509_S:] AT+CREG?
[2022-11-05 10:53:28:522_R:] AT+CREG?
[2022-11-05 10:53:28:522_R:] +CREG: 0,3
[2022-11-05 10:53:28:522_R:] OK
[2022-11-05 10:53:28:539_S:] AT+CGREG?
[2022-11-05 10:53:28:551_R:] AT+CGREG?
[2022-11-05 10:53:28:551_R:] +CGREG: 0,4
[2022-11-05 10:53:28:551_R:] OK
/* Make sure the Antenna is connected and the network is normal */
thanks
For your convenience, I attached other AT commands here:
/* Use AT+CPIN? to query the SIM card status : SIM card inserted or not, locked or unlocked */
[2022-11-05 10:59:10:463_S:] AT+CPIN?
[2022-11-05 10:59:10:483_R:] AT+CPIN?
[2022-11-05 10:59:10:483_R:] +CPIN: READY
[2022-11-05 10:59:10:483_R:] OK
/* Use AT+CSQ to query current signal quality */
[2022-11-05 10:59:10:510_S:] AT+CSQ
[2022-11-05 10:59:10:531_R:] AT+CSQ
[2022-11-05 10:59:10:531_R:] +CSQ: 13,99
[2022-11-05 10:59:10:531_R:] OK
[2022-11-05 10:59:10:564_S:] AT+CREG?
[2022-11-05 10:59:10:581_R:] AT+CREG?
[2022-11-05 10:59:10:581_R:] +CREG: 0,3
[2022-11-05 10:59:10:581_R:] OK
[2022-11-05 10:59:10:599_S:] AT+CGREG?
[2022-11-05 10:59:10:616_R:] AT+CGREG?
[2022-11-05 10:59:10:616_R:] +CGREG: 0,4
[2022-11-05 10:59:10:616_R:] OK
/* Use AT+COPS? to query current Network Operator */
[2022-11-05 10:59:10:652_S:] AT+COPS?
[2022-11-05 10:59:10:677_R:] AT+COPS?
[2022-11-05 10:59:10:677_R:] +COPS: 1
[2022-11-05 10:59:10:677_R:] OK
Please help me with this. Thank you.
This message indicates that RRC connection has been established between the module and the base station. As for the rejection, I personally think it is caused by APN. Please check the APN of your SIM card again, and configure it by AT+CGDCONT, and then test again
Hi, I just bought another SIM card from Telstra. I configure APN by AT+CGDCONT=1. “IP”, “telstra.internet” and then reset the module. Now it is connected. Next I will try to see whether the module can be connected using a Vodafone SIM again. Thank you very much for your help.
I configured the APN by AT+CGDCONT=1, “IP”, “spe.inetd.vodafone.nbiot” after inserting the Vodafone SIM and resetting the module. Still get no luck with Vodafone SIM. The registration is still denied. Please help! Thank you.
Thank you. I have followed the suggestions on that site. It just changes from “registration denied” to 'not registered", even after trying that setting. set the APN and reboot the module.
