Regarding latest firmware update for BC660
@herbert.pan-Q I cannot upgrade the chip set BC660K-GL. I’m using the latest Qflash software available (V6.9). Here on this screenshot, the left side is the debug port. I press down the boot button, reset the device and wait while holding the boot button. It times out every time. I’ve selected the appropriate baud rate/main port configuration. These files are all up to date, and are provided by the support team.
You should disconnect the TXD/RXD from the mcu
I tried that but the result is the same. Is there a way to send at+qsclk=0 and save that to the memory of the device? It defaults to sleep mode every time I boot it. If I could save the sleep mode parameter; maybe then I could start the device in the download mode
I’m not sure what the problem was but I think it had to do with usb port configuration in my computer. Both machines, the one in which QFlash did not work and the one in which it did, were running Windows 10.
could you provide the newest f
This is my current firmware version:
Quectel_Ltd
Quectel_BC660K-GL
Revision: BC660KGLAAR01A05_01.001.01.001
Thank you!
I have sent it to your email,pls check,and I hope you can click the :yellow_heart: for me,thx
Hi.
Please send latest firmware, for BC660K-GL
Thanks.
Hi
Could you please send me latest firmware and Qflash tool?
My email is bestvirut@gmail.com
My module version is below,
ATI
Quectel_Ltd
Quectel_BC660K-GL
Thanks in advance.
Hi
Could you please send me asap the latest firmware and Qflash tool?
My email is ea@x-log.de
My module version is:
Quectel_Ltd
Quectel_BC660K-GL
Thanks in advance.
Hello, i would also like the latest firmware for the BC660K-GL-TE-B dev board, please.
my email: bruno.martins@institutoiracema.org.br
Hello, ATI command of my module returns:
Quectel_Ltd
Quectel_BC660K-GL
Is there newer firmware for BC660K? Thank you.
I got the link but when I enter my e-mail and click send I don’t receive any verification code from Microsoft OneDrive. I think Microsoft has some problem or yahoo filters the verification e-mail at high level and the mail is never received in any folder (even if I add their e-mails to my address book). Can you share to another e-mail - lubchoh@abv.bg - maybe that will work better.
I have sent it to your email again
Got it this time! I guess Yahoo mail and Microsoft one drive don’t work together. Thank you!
Hello, we got BC660KGLAAR01A05_01.205.01.205, is there a newer version for the BC660K-GL?
Thank you.
