Regarding latest firmware update for BC660
Hello, you need the latest firmware for that module.
yes pls send me! I used BC660KGLAAR01A04, Is it the latest?
hi,
The latest firmware has been sent via email, please check it out.
Hi, I used module BC660k-GL to connect NB, Currently I can only use NBcat1. How can I use NBcat2?
hi ,
You can change catgory to 2
Your local radio network also needs to support NB2
I have
AT+QGMR
Quectel_Ltd
Quectel_BC660K-GL
Version: BC660KGLAAR01A05_01.001.01.001
Can I ask you to send me the latest firmware version?
My email: scartssi@gmail.com
Thanks,
Marek
@AnnaLiu I have following version
Quectel_BC660K-GL
BC660KGLAAR01A04_01.002.01.002
Could you please provide FW version one before the latest one (Version: BC660KGLAAR01A05_01.001.01.001)
my email: mikhail.bocharovv@gmail.com
Thanks in advance!
I have sent it to you
A colleague has sent it to you.
Hi @AnnaLiu, could you please send me the last firmware version for BC660K? I need to enable SSL SNI, is it included in the latest firmware?
The latest firmware version of BC660K still does not support SNI
Could you send me QFlash tool and latest firmware?
[2024-02-19 14:01:08:826_R:] OK
[2024-02-19 14:01:08:846_S:] ATI
[2024-02-19 14:01:08:915_R:] ATI
[2024-02-19 14:01:08:915_R:] Quectel_Ltd
[2024-02-19 14:01:08:915_R:] Quectel_BC660K-GL
[2024-02-19 14:01:08:915_R:] Revision: BC660KGLAAR01A04
I have sent them to you
Thank you. I get it.
Hi. Please send latest firmware to rl78family@gmail.com.
I need to restore my BC660K to factory firmware, because it doesn’t respond to AT commands.
Someone played with the module and flashed custom firmware.
I’m struggling with the same problem as well. How did you solve the issue? I’ve tried Qflash on a different PC (win 10) but it did not work. I get the same error. Did you try it on Windows 7 or was it another non-win10 environment?
Yusuf
Could you describe your problem in detail?
