Quectel EC25 firmware
I seem to be having an issue receiving the authentication code to download the zip folder. Does everything seem okay on your end?
I have resent the link to you. Please try again. If it still fails, you will need to provide a shared storage space. I can then upload the firmware to it.
I seem to be having the same issue. We can try the shared space or you can send that link to my personal email if you would like. My email is as follows gnapolitano198@gmail.com
Good day!
Kindly, share the latest firmware for devices: Quectel EC25-E
Current firmware is: EC25EFAR08A05M4G
We are using these devices in Qatar.
Than you!
can you please send me the latest EC25-E firmware?
Current firmware version is EC25EFAR06A11M4G
Thanks!
I have resent the firmware to the email,pls check
Yes, I have sent it to your email. Please check if you have received a shared link.
My EC25 is running EC25EFAR06A18M4G. How old is this firmware?
I face modem keeps resetting it its running for long time, (2-3 days), then no only solution is to power cycle the entire board. Is this a known issue for this firmware?
Can you please share the latest version as well.
email: aish84@gmail.com
I have sent you the latest firmware version to your email. After upgrading, please recheck and test to see if the problem still persists.
Thank you very much,
I am running openwrt and EC25-E is attached to the mPCIE slot. How to upgrade it while its UP.
Does QFirehose help in this case, can you please provide this and steps to upgrade the firmware?
I did upgrade the firmware with QFirehose successfully while modem was attached to the router (but not in use). Just unpack the firmware zip file into a subdirectory and run QFirehose like this:
QFirehose -f EC25EFAR06A21M4G
where EC25EFAR06A21M4G is the subdirectory that contains the firmware.
You’ll need to have QFirehose compiled for the host architecture. The source code is at Github.
There is a video tutorial at How to upgrade module thru Linux QFirehose
Quectel EC25 — AT+QENG not responding in CMUX connected mode (ArduPilot LTE modem driver)
Module: Quectel EC25E Firmware: EC25EFAR06A18M4G Setup: ArduPilot Lua LTE modem driver, CMUX enabled, UDP data connection active
Issue:
Using the ArduPilot LTE modem Lua script with a Quectel EC25E module. The script sends AT+QENG="servingcell" every 1 second via CMUX DLC1 to get serving cell information (CID, TAC, RSRP, RSRQ, SINR, band) for logging to the flight controller’s dataflash log.
The command is being sent correctly — confirmed via serial log. However the EC25 gives no response to AT+QENG="servingcell" on the CMUX AT channel (DLC1) once the UDP socket is open. AT+CSQ on the same channel works fine and returns a response every second. AT+QENG works normally when tested directly on the UART before the socket is open.
-Is this a known restriction in EC25EFAR firmware — AT+QENG blocked on CMUX AT channel during active data session?
  1. Is this fixed or improved in a newer firmware version? If so, which version should I target?
  2. Is there a different command or QCFG setting that would allow QENG to respond while a socket is active?
I currently have this version:
EC25
Revision: EC25EFAR06A18M4G
can i get the latest version of EC25
I am interested in getting the latest firmware for EC25-EUX device.
Thank you!
do you have firmware update instructions using CLI - debian?
Hi Mikey,
Please send me the latest firmware version for EC25-E
My version is EC25EFAR06A17M4G.
Regards
I have sent the latest firmware to your email, pls check
