QGNSS V1.10 does not seem to apply RTK data to LC29HEA fixes
I have firmware LC29HEANR11A03S_RSA,2023/10/31,16:52:14*2B
I am connected to an RTCM3 NTRIP mount point and I am receiving RTK data every second but the RTK data does not seem to be applied to my fixes in QGNSS V1.10.
Any ideas why? Here is QGNSS V1.10 screenshot:
Thanks,
Dale
I think the latest firmware does…:-1:t5:
I don’t know what is the matter, try some suggestion from this list.
$PAIR382,1*2E → Test command for lock system sleep enabled
$PAIR003*39 → power off GNSS system
$PAIR514*3A  Clear the current configuration and restore the default settings set via $PAIR
$PAIR512*3C  clear all data
$PQTMRESTOREPAR*13 # restore $PQTM params to default
$PAIR023*3B   reboot  module
$PAIR007*3D → Full cold start and clears system and user configurations
$PQTMGNSSSTOP*09  same of power off GNSS system
$PQTMCFGRCVRMODE,W,1*2A  # set receiver to rover mode
$PQTMCFGRCVRMODE,R*32  ask & get result
$PAIR863,0,0*37  ask & get bit_mask config [♣default is $PAIR863,1791*15 (DEFAULT)]
$PQTMSAVEPAR*5A # save PQTM params to flash
###for useful     $PAIR002*38 → power on GNSS system
$PAIR062,1,0*3F   # turn off GLL messages (1
$PAIR062,2,0*3C  # turn off GSA messages (2
$PAIR062,3,0*3D  # turn off GSV messages (3
$PAIR062,5,0*3B  # turn off VTG messages (5
$PAIR063,-1*0F  ask if done: see pos. after -1       $PAIR063,-1,1,0,0,0,1,0*0F
        0,1,2,3,4,5
$PQTMCFGNMEADP,W,3,8,3,3,3,3*39  -->configure ALL to MAX decimals
$PAIR050,200*21 # set pos output interval to 200 ms
$PQTMCFGFIXRATE,R*71  ask & get result
$PQTMCFGFIXRATE,W,200*6A  same as set pos output interval to 200 ms
$PAIR753,1*26   enhance the PPS output timing accuracy but remove SBAS/QZSS effects)
####for testing
$PAIR410,1*22  enable sbas satellite
$PAIR410,0*23  disable
$PAIR411*3E  ask
$PAIR400,2*20  enable sbas input dgps
$PAIR400,1*23   **enable rtcm correction input dgps**
$PAIR401*3F  ask & get status
$PAIR035*3C  get fix status
$PAIR864,0,0,460800*16 set baud
$PAIR864,0,0,115200*1B
$PAIR865,0,0*31   Queries the baud of uart_port  and response.
$PAIR062,0,1*3F  # Keep on GGA messages
$PAIR062,4,1*3B # Keep on RMC messages
$PAIR100,1,0*3A  1: **ASCII NMEA v4.1 output** only
$PAIR511*3F\r\n  Save current navigation data from RTC RAM to flash
$PAIR432,1*22\r\n ==> set RTCM3.x output with type MSM7  only in base_mode *but not save setting after reboot*
$PQTMCFGMSGRATE,W,PQTMEPE,1,2*1D          how accurate is the obtained position
$PAIR862,0,0,239*22  for base_mode special bitmask
$PQTMCFGSVIN,W,2,0,0,x,y,z*<Checksum> in ecef
$PAIR604,<Enable>,<Mode>,<Para1>,<Para2>,<Para3>*CS<CR><LF>
$PAIR604,1,0,x,y,z*<Checksum>  in ecef
$PAIR604,1,1,La,Lo,H*<Checksum>  in WGS84, (Lat,Lon,Height)
$PQTMCFGRTK,R*69   $PQTMCFGRTK,OK,1,1*3F     $PQTMCFGRTK,W,1,1*6C  default_set.
$PAIR473,1*27   Enable EPO flash aiding
Where does the RTK base station data get applied to the GPS coordinates?
I would like to assume that the LC29HEA should receive the RTK NTRIP client data from the internet by USB and then combine it internally so that NEMA data that is output from the LC29HEA should be ~1CM fixes.
I have tried a bunch of your commands with no luck for getting RTK fixes but it is very curious that the setting for the fix rate to 200ms does not seem to work as shown here:
what is the output, it seems not in rover mode…
https://forums.quectel.com/uploads/short-url/gJTnPOK8MkEJIgLFR7QgjvrpUey.pdf
https://forums.quectel.com/uploads/short-url/ncdKSn5cRYyDbOpfYmvGGs1vEIA.pdf
I have been using that last doc for EA model and I use online NMEA checksum calculator https://nmeachecksum.eqth.net/
I had already checked the rover mode (it was already in rover mode when I first queried it but I did it again, here is result:
Ok, and now should do apply for 200ms…once rebooted or not?
Here is a reboot and then again no ability to set to 200ms (no response from LC29HEA when attempted):
Strange…can U print and redo PQTMVERNO*58 ?
is
$PQTMVERNO,LC29HEANR11A03S_RSA,2023/10/31,16:52:14*2B
Hello Dale , it seems that your module has not ingested the new firmware…if after a new fw_update procedure U see no difference, open a new topic and describe the situation by saying what kind of evb card you have where you bought , what was the original fw etc. and explicitly request support in addition to an “[official
]” firmware.
P.s. at least moves to 1hz with $PQTMCFGFIXRATE,W,1000*59 ?
let me know
Marco
Hi Marco,
But first, just another data point here…
This morning I woke up and just tried setting to 200ms again and surprisingly I got a response that confirmed it heard me and then requested the current fix rate status and it had appeared to change it to 200ms as you can see here:
That was good news but when I filtered to RMC text data I was still receiving fixes at 100ms as you see here:
I will now start a topic to ask for a link to latest firmware since I do not have any .cfg (etc) files…
Thanks,
Dale
Good for now, the native pair command should go directly to the new fix rate: $PAIR050,200*21 → set pos output interval to 200 ms 5 Hz , however save $PAIR513*3D save file system and reboot $PAIR023*3B reboot module for take effect.Later see message_box.
Bye
Marco
WOW, that was at least successful:
But still no RTK data applied to fixes :frowning:
Fixes are in GGA string $PAIR062,0,1*3F enable GGA
I have all 1s, (GPS fixes):
Interesting that you get 4 and 5 which is not described in the NMEA standard for GGA
Quectel, on Airoha AG3335A chip use ASCII NMEA v4.1 format
Good info, thanks!
Florida welcomes Hefei :wink:
…however someone managed to…with LC29H-DA sold as EA
stay tuned on this forum
@Oli is the bridge between the forums.
I got mine here, https://www.aliexpress.us/item/3256806670819614.html and it seems to be an EA since it updates at 10hz:
BUT no RTK fixes yet…
BTW I can’t find a download of that 4.1 standard, only 1 very expensive method found so far:
I want to use two EAs mounted 1.5m apart on my zero turn lawnmower (using 2 lets me also calculate heading)
I will write my own code like Mission Planner with direct control of the mower with my own PID algos…
