Hello.
I’m trying to develop GPS app, but have some troubles. MC60 do not response on AT+QGNSSRD?.
Version of firmware is A13.
I tried to reflash firmware, but had an error on gps state.
What can be wrong?
Hello.
What can be wrong?
I’m sorry to reply you so late.
Did you excute AT+QGNSSC=1 to power on the GNSS?
make sure your module is in all-in-one solution mode.
please refer below image.
Also execute the AT+QGNSSC=1 to power on the GNSS.
Hello sir,
According to the example provided in SDK for example_gps.c, I compile it and reflash my MC60E module.
As shown in the example, all are callback functions and it should print all debug messages on the main port, but only "-- Ril is initialized "message coming on the serial port and nothing appear after that.
According to the user manual for GNSS engine, i have short J106 and also short GNSS_UART with AUX_UART to get data. but it not working.
According to the user manual D102 led should lit up but it’s not working.
To cross verify I also connect UART3 to PC but nothing appears on the screen.
What could be the problem?
Thank you.
Hi Nayan ,
Are you using EVB or your OWN board ?
We need to make GNSS_VCC supplied to make GNSS ON .
Thank you
Ratan
I have an EVB kit.
As shown in the pic I have short auxiliary pins and GNSS pins through a 1k resistor, still not working.
Whenever I power the GPS engine send data on the UART3 port, but according to example_gps.c I register UART1 for the reception for GPS data then it should dump data to the main port. But it’s not happening.
Hi ,
you need not to short that using Resistor , you just need to put both switch in ON condition .
For GPS to make On with example_gps.c , you need to give one command from main port .
See below , I sent “GPSOpen” and "GPSRead=“ALL” from main port .
Off course you can modify code to make these things automatic .
01-03-2021 18:56:21.912 [RX] -
<-- OpenCPU: GPS Example -->
<-- RIL is ready -->
01-03-2021 18:56:24.759 [TX] - GPSOpen
01-03-2021 18:56:24.792 [RX] - Power on GPS Successful.
01-03-2021 18:56:31.974 [TX] - GPSRead=
01-03-2021 18:56:32.032 [RX] -
+QGNSSRD: $GNRMC,235947.094,V,0.00,0.00,050180,N5C
$GNVTG,0.00,T,M,0.00,N,0.00,K,N2C
$GNGGA,235947.094,0,0,M,M,55
$GPGSA,A,1,1E
$GLGSA,A,1,02
$GPGSV,1,1,0079
$GLGSV,1,1,0065
$GNGLL,235947.094,V,N67
Hello Sir,
I have an MC60E EVB kit and I’m looking for an OpenCPU example to communicate with AWS.
I already gone through a topic which is raised by a person on this forum the link is
He is using an external MCU to communicate with MC60E chip. I also did same procedure by qcom software and i successfully able to send and recive messages from AWS. and vice versa
Now I am looking for a Example code in OpenCPU SDK to communicate with AWS.
If there any code available to communicate with AWS using MC60E OpenCPU SDK, please do share it with me.
Thank you.
