Linux PCIE drivers
Can you please send me the linux PCIE drivers Quectel_Linux_PCIE_MHI_Driver and Quectel_Linux&Android_SPRD_PCIE_Driver, latest versions? Thanks!
Thank you.
Also, is there a new firmware for RM510Q-GL? I have RM510QGLAAR11A02M4G
Thank you. Is this to be used with qflash? Are there any instructions?
Edit: looks like I need this: Quectel_LTE&5G_QFirehose_Linux&Android_V1.4.5.zip
Edit: I manged to find firehose and I updated the firmware, but now PCIe mode doesn’t work anymore:
at+qcfg="data_interface"
+QCFG: "data_interface",1,1
[   28.239843] usbserial: USB Serial support registered for GSM modem (1-port)
[   28.239877] option 1-9:1.0: GSM modem (1-port) converter detected
[   28.239951] usb 1-9: GSM modem (1-port) converter now attached to ttyUSB0
[   28.239983] option 1-9:1.1: GSM modem (1-port) converter detected
[   28.240033] usb 1-9: GSM modem (1-port) converter now attached to ttyUSB1
[   28.240061] option 1-9:1.2: GSM modem (1-port) converter detected
[   28.240102] usb 1-9: GSM modem (1-port) converter now attached to ttyUSB2
[   28.240132] option 1-9:1.3: GSM modem (1-port) converter detected
[   28.240176] usb 1-9: GSM modem (1-port) converter now attached to ttyUSB3
[03-15_12:07:53:232] QConnectManager_Linux_V1.6.1
[03-15_12:07:53:232] Find /sys/bus/usb/devices/1-9 idVendor=0x2c7c idProduct=0x800, bus=0x001, dev=0x002
[03-15_12:07:53:232] network interface '' or qmidev '' is not exist
[03-15_12:07:53:232] qmidevice_detect failed
[03-15_12:07:53:232] atdevice_detect failed
Even tho I set 1,1, it’s still being recognized as USB, why?
Beacause of the issue from above, would it be possible to downgrade? Can you supply the previous firmware, RM510QGLAAR11A02M4G?
Dear Sir,
Qflash is used for Windows, below is the link with RM510QGLAAR11A02M4G, thanks!
I’ve downgraded to A02, but the module still isn’t switching to PCIe mode. Is there anything I can try to diagnose why it’s remaining in USB mode?
Please check initialization time sequence of the PCIe interface, what is your external CPU?
Hi Peter, Can you share the doc to me ? I want to port the PCIe Linux driver for RM500Q-GL too.
Dear @Hoff_Cheng
I have sent it to you in another topic, please check.
Hi Peter, can you please send me the linux Quectel MHI driver too
Thanks very much
Please check the message. I have sent you the 1.3.6. @Krishna
Thanks, will try it.
Hi Bean, can you please send me the linux Quectel MHI driver too
Thanks very much
Dear @buanfengzi
Please contact with your provider firstly next time, they have access to get the latest driver.
@Bean.Wang-Q can you please provide me the Quectel_Linux_PCIE_MHI_Driver_V1.3.1.zip
as well?
Or latest one of course!
Dear @Fabian_Richter
Could you please send me the linux pcie drivers as well.
Thank you.
Dear @Dimsum
