Linux PCIE drivers
Hi the link expired could you please share the download link again ?
Dear @divyansh
I like to request for the Linux PCIE drivers for Linux machine and the PCIE driver user guide.
Thank you.
Hey,
I would like to request the Linux PCIE drivers for the RM520N-GL please.
I am working on a raspberry Pi Compute Module 4 running:
Linux cm4 6.6.62+rpt-rpi-v8
Many Thanks
USB or PCIe.
For USB please follow the Quectel_UMTS_LTE_5G_Linux_USB_Driver_User_Guide_V3.2.pdf to port the usbserial driver and the qmi_wwan_q.
And you need the quectel-CM to set up datacall.
I already got the USB to work thanks. I would like to try the PCIe though. As far as I understood it should be possible to have the Data transferred over PCIe. While the AT commands are send via USB.
I designed a custom board to connect the CM4 to the module. Therefore I would like to test my PCIe connections.
again Thanks for your help.
Please try the pcie_mhi. I’ve sent it.
Hi Bean, I’m trying to achieve a stable operation of EM120R-GL on Linux as described here: https://www.reddit.com/r/Lenovo/comments/zmxher/making_the_quectel_em120rgl_lte_modem_work_with/?rdt=43708
Can you send me the required Quectel_Linux_PCIE_MHI_Driver_V1.3.1.zip file?
Please check the PCIE_MHI I sent.
Hi! I’d like to request Linux driver for EM120R-GL please, also manual if possible.
Hi, can you help me with PCIE_MHI, I am following same Reddit tutorial?
Dear @bpo50
Is anyone able to share the Quectel_Linux_PCIE_MHI_Driver, and anything else I need for Raspberry PI 5 with OS 6.12.38-v8-16k+ with RM520NGL modem? Thank you
Dear @hunter
I have sent to you via message, please check.
Thank you! Does this need to used on a kernel with normal MHI enabled or is this a replacement for all of that functionality? Do I also need Q Connector too?
Dear @hunter
Quectel_Linux_PCIE_MHI_Driver is a driver, you can try to install and test.
Hello!
I’d like to request the Quectel_Linux_PCIE_MHI_Driver files as well.
Thank you.
Dear @Obedience0035
Hello!
Thank you.
Dear @Alexis_Orloff
