does the EA version of the LC29H support raw data output via RTCM3 or is it only available to the BS model?
I have a module with the following firmware $PQTMVERNO,LC29HEANR11A03S_RSA,2023/10/31,16:52:14*2B
The corresponding pair commands do not seem to respond (pair432, pair436) , rtk via rtcm3 injection works flawlessly and other commands.
thanks in advance
Best regards
Bruno Gouveia
thanks bamarcant, it’s definitely interesting but no, there’s nothing about rtcm3 output in that document
Here is a blog post that answers your question:
Configuring the Quectel LC29HEA receiver for real-time RTK solutions
The base station was configured as such:
$PQTMRESTOREPAR*13 # restore PQTM params to default and reset
$PQTMCFGRCVRMODE,W,2*29 # set receiver to base mode
$PQTMSAVEPAR*5A # save PQTM params to flash
# manually power cycle module
$PAIR432,1*22 # output RTCM3 MSM7 messages
$PAIR434,1*24 # output RTCM3 antenna position (1005)
$PAIR062,0,01*0F # Enable NMEA GGA message
$PQTMCFGSVIN,W,2,0,0,x,y,z*3B # set base location in XYZ coords
Once again a great job of Tim Everett…
Thanks for sharing.
Thank you for the @ , I should have checked to see if the author had an account on this forum.
@rtklibexplorer Thank you for the great blog!
@george.gao @Raphael-Q (@ any other Quectel staffers), @rtklibexplorer brings up a good point in his blog post linked above. On an LC29H(EA) running version LC29HEANR11A03S_RSA,2023/10/31,16:52:14 when I set the RTCM output to MSM7 using the $PAIR432,1 command, it works as intended. However the $PAIR513 and/or $PQTMSAVEPAR commands seem to be saving the configuration to output MSM4 messages rather than MSM7 after a power cycle.
Is this a known bug? Is there fixed firmware? Is there a work around other than running $PAIR432,1 on every boot?
It seems to be due to the PQTMCFGRCVRMODE settings…in (2) base mode,
relating to a set of preset PQTM proprietary instructions, despite
the module is based on the AG3335A chip and supports native PAIR commands, the module do not output RTCM messages in 0 and 1 setup.
