LC29H (EA) settings into new firmware
Continuing the discussion from LC29H (EA) RTCM3 out?:
Hello respectable Staff, in addition to this report I can confirm that even the command $PAIR062 is not saved after the restart (in base mode).Example I can send $PAIR062,0,1*3F and confirm with $PAIR063,0*23 the good result or operate all with
$PAIR062,-1*0E ; ask: $PAIR063,-10F resp.: PAIR063,-1,1,1,1,1,1,1,10F
and save with $PQTMSAVEPAR*5A or with $PAIR513*3D but after a reboot the setting returns to $PAIR063,-1,0…
I would also like to know about the new $PQTMCFGRTK,R*69 setting if there are other parameters besides $PQTMCFGRTK,W,1,1*6C → $PQTMCFGRTK,OK,1,1*3F by default.Regards
Marco
Hi Marco,
It’s recommended to configure satellite system by sending PQTMCFGCNST command. I will send you the latest protocol specification via message.
Best regards.
Thanks a lot Raphael for the support, I was also curious about the $PQTMCFGRTK command mentioned in the firmware release:
Hi @Raphael-Q
Can you please send that one to me too ?
Best regards
Hi Bgouveia,
Best regards.
