Latest firmware for RM520N-GL
Please send me the latest firmware for RM520N-GL.
Thanks.
Hi, Sir
Could you please me the specific version in your side?
  Hardware |            manufacturer: quectel
           |                   model: RM520N-GL
           |       firmware revision: RM520NGLAAR03A03M4G
           |          carrier config: ROW_Commercial
           | carrier config revision: 0A010809
           |            h/w revision: RM520N-GL
I will share that via email. Thx
Hi. Can I please have the latest firmware for Europe for RM520NGLAAR03A04M4G.
In my GL-X3000
Dear @Erik_Olsson
Can you please also send me the latest firmwares for the RM520N-GL, for both branches (R01 and R03)?
Thank you.
Dear @CellMonster
Dear Silvia,
Thank you very much for sending the firmware files.
I have a couple of questions to help me understand the versioning, as some of it is a bit confusing. I would be grateful if you could help clarify.
My first question is about the two “R03” versions. The new file you sent has a newer date but seems to have an older version number.
Here are the details:
The OLDER firmware I WAS using:
  • File: RM520NGLAAR03A04M4G_01.204.01.204.zip
  • Version: R03A04
  • Date: 2024-10-22
The NEWER firmware you sent:
  • File: RM520NGLAAR03A03M4G_A0.300.A0.300.zip
  • Version: R03A03
  • Date: 2025-04-28
Could you please explain why the firmware with the newer date has a lower version number (R03A03) than the older one (R03A04)?
My second question is about the difference between the “R01” and “R03” release paths. You also sent me this file:
  • File: RM520NGLAAR01A08M4G_01.206.01.206
Could you explain the difference between the R01 and R03 firmware series? When should I use the R01 version, and when should I use the R03 version?
For context, I did test that R01A08 version previously, but I experienced some instability issues with it, so I switched back to an R03 version which was more stable for me.
Finally, on a side note for your team and other users that might to try to use this firmware:
My router (a GL-iNet Spitz AX X3000) gave an “incompatible” error when I tried to install the new R03A03 firmware through its web interface. However, I was able to flash it successfully using the QFirehose tool from the command line, and it is now connected and working with great stability.
Thank you for helping me clarify these points.
Best regards,
CellMonster
If possible could someone also send me the latest firmware for RM520N-GL please.
My current firmware is: RM520NGLAAR03A03M4G
Many thanks.
Hi,@Biggles
I’ve sent it via private message.pls check.
Hello. Can I get this version: RM520NGLAAR03A03M4G_A0.300.A0.300.zip
Thank you
Hi,@Andy.alex
Could you tell me your current firmware version?
Received Leon, many thanks. :heart_hands: :heart_hands:
Hello
Hi,@Andy.alex
I have sent to you via email,pls check
Dear @CellMonster
=>You don’t sent me the current firmware, so I sent the R03A03, R03A04 and R03A04 has some different, like certification. And power class is different.
=>R01 will not be maintained later, you can use R03 baseline.
=>For this, you need to check with your router manufacture.
I will sent R03A04 firmware to you, you can try again.
Subject: Firmware + Flash Tools for RM520N-GL
Hi Quectel Support,
I am working with an internal RM520N-GL module
(firmware: RM520NGLAAR03A03M4G) inside my laptop. Please provide the latest firmware package and compatible flash tools (QFlash_PCIE or others) including firehose files for SDX55.
Thanks,
Amed
Dear Silvia,
thank you very much.
RM520NGLAAR03A04M4G_A0.300.A0.300 installed just fine and seems to work well.
Also thanks for the interesting explanation about the differences between R03A03 and R03A04. Do I understand correct that R03A04 has a higher power class / power limit, hence can potentially transmit faster than R03A03?
Thank you very much :slight_smile:
If u have the firmware of RM530N-GL PLEASE SEND ME A LINK .
I am looking for the RM530NGLAAR05A01M4G
