Hi,@Amed
I have sent it via private message.pls check
Hi,@VINNI
Your current firmware is the latest one.
Dear @CellMonster
Sorry, I don’t think they have any correlation.
Dear Silvia,
thank you, but what exactly do you mean with “no correlation”? You said R03A03 and R03A04 have different power class - so what do you mean by that?
Thank you,
CellMonster
Dear @CellMonster
R03A03 is PC2, R03A04 is PC1.5.
But it seems there is no direct relationship between PC and transmit faster.
Dear Silvia,
thank you, but there is clearly a connection. The PC2 specification has a TX limit of only 26 dBm, while the PC1.5 spec has 29 dBm. There is a HUGE speed difference between both standards because 29 dBm are double the transmission power of 26 dBm. There is also a field study that confirms this:
Thank you.
can you please send me the latest firmware, current firmware and firehose for the following RM520N-GL
ATI+QGMR
RM520N-GL
Revision: RM520NGLAAR01A08M4G
RM520NGLAAR01A08M4G_01.200.01.200
thanks
Hi,@rchris494
I have sent it to you via email,pls check
Hello, can I also get the latest firmware? This is what I currently have:
RM520N-GL
Revision: RM520NGLAAR03A03M4G
RM520NGLAAR03A03M4G_01.201.01.201
Hello, I would also live the latest firmware + some instructions on how to update.
I now have the Quectel RM520NGLAAR01A08M4G and am using the m.2 directly via Ubuntu
Cheers!
thanks for the firmware
Hi,@werty
I have sent to you via email,pls check.
Hi,@Robin_Anders
I have sent them to you via private message,pls check.
Hello, is there RM520N-GL 5G firmware for EU telecom and eSIM function enabled? May I request the latest and finest please?
Hi,@mister.bagger
Could you tell me your current firmware version?
Thanks.
I never got the email, can you send it again ?
Hi,@werty
I have resent to you via private message,pls check.
Hi,@mister.bagger
Received, thank you @leon.bao
