Hello
I have an EC21 module. I heard from a Quectel engineer that I can use QuecOpen, but I’m not sure how to use it. Can I get a detailed explanation about this?
Thank you
Hello
Thank you
hello @wireless
Please send a email to support@quectel.com, or ask for the administrators of the forum @Akso.xie and @eddy to indicate you a moderator that can guide you in a way to properly use and test your EC21 device.
I apologise for not having the knowledge enough to help you.
Best Regards
ShortyPTG
Hello,Akso. Xie and Eddy aren’t in charge of the forums category. Each section has corresponding technical moderator responsible. Due to the large number of posts, they need time to reply. Please be patient, and we will also push them to support you as soon as possible.
Thank you for your understanding.
Hi @wireless
First you need to get the QuecOpen SDK, I’m not sure if you already have it.
Then you need a development environment, such as ubuntu16.04, or 18.04. The code needs to be compiled here, and finally the USB driver for the corresponding environment needs to be installed, so that you can start your development.
The following video explains how to compile and run an application using the sdk, hope these can help you.
Thank you for your response.
I’m curious about how I can obtain the QuecOpen SDK.
