Hello.
I’ve some Quectel EG25-G and i’m having some problems with carrier disconnections.
The modem is plugged on linux and works with qmi mode.
On boot, the wwan interface up with
qmicli -p -d /dev/cdc-wdm0 --wds-set-autoconnect-settings=enabled
qmicli -p -d /dev/cdc-wdm0 --device-open-net='net-raw-ip|net-no-qos-header' --wds-start-network="apn=internet.com, username=, password=" --client-no-release-cid
udhcpc -q -f -n -i wwan0
Is there any additional configuration required for the connection to be reestablished automatically?
Therefore, there is no problem in establishing a normal data connection. Isn’t it? But you can’t reconnect automatically. You may want to consider using quectel’s Quectel-CM tool, which supports automatic reconnection.
As I know, if you try the libqmi, it does not support auto reconnect.
Thank you @Bean.Wang-Q
Can you share with me any link about Quectel-CM tool to download it?
Please try it. I have sent it via message.
Please discuss here.
qcm.service
[Unit]
Description=just for quectel-CM
After=Network.service Resolv.service
[Service]
ExecStart=/usr/bin/quectel-CM
[Install]
WantedBy=multi-user.target
# sudo systemctl daemon-reload
# sudo systemctl enable cm.service
I was testing with this service and seems works fine
[Unit]
Description=Quectel-CM tool
Wants=sys-devices-virtual-net-wwan0.device
After=sys-devices-virtual-net-wwan0.device
[Service]
Type=simple
Restart=always
RestartSec=30
RemainAfterExit=no
[Install]
I’ve another reaetd question.
How can I the signal strength using quectel-CM tool, for example, that I previously requested with qmicli -p -d /dev/cdc-wdm0 --nas-get-signal-strength ?
Please check the source code of quectel-CM.
Try open the MICRO
QMIThread.h
9://#define CONFIG_SIGNALINFO
Or you can send AT
AT+QCSQ
AT+QENG=“servingcell”
Perfect!
I see the signal info on the log.
Thanks for the quick support
Can you send me the cm tools too? Thanks!
Please check the message.
