How to get Quectel standard firmware
Dear customer,
Thank you for your support of Quectel products.
In order to be more convenient for you to get new standard firmware, we would like to recommend you reach out to support@quectel.com mailbox and share the following information for better support(only for firmware).
If you purchased the terminal device, we sincerely suggest that you can contact the seller for help first, they may provide better support.
1-Your Company Name(if you are not an Individual developer)
2- R&D location(City)
3- From where you bought Quectel module
4- Your current firmware version(command:ATI)
We will have dedicated engineers to support you.
If you want to get the QuecOpen SDK, please refer to this post.
For technical issues, welcome to continue to communicate in the corresponding category (LPWA/5G/LTE etc.)on the forum.
I have a Qualtec 5G NR SIM Router.
My current firmware file is:
RG500UEAABxCOMSLICv3.2.2543.12.18
Is there an update available?
Thanks.
mr_mike_smith@hotmail.com
I need the Latest driver for Quectel EM06-E module and also provide me steps to install it, I am using Linux (Ubuntu) as O.S
@lyman-Q add lyman to support EM06-E issue, add @silvia to support 5G issue
jason hanson, fairfax, sc usa. bought off amazon
ec25afxgar07a04m1g
want firmware if needed. having all kinds of connection issues. windows 11 pro with at&t sim
I see so many people asking for firmware and drivers and the response has been absolutely terrible. I went to your downloads area and it is absolutely 100 percent unclear which is which. You have so many usb drivers that are not labeled for what modem card they support. This level of support is unacceptable and based on this, I would recommend almost any other vendor that can handle a snapdragon comm module.
I have the same question another person has which is "I need windows driver for the RM530N-GL and your incredibly unhelpful response is to say “download the ndis drivers” How lazy. Make a download that is labeled with the card the drivers support and put it in the download area.
Also, what is the problem with you guys getting certified with Verizon for the 530 already? I tried to activate and they said it was an unsupported devices.
My impressions so far of Quectel are poor to the say the least. Do better.
Also, the pricing for your dev board for this modem is offensive. 2 grand for the privilege of getting a QTM545 module connected is plain rude.
I am not impressed with your company whatsoever.
Can I get an updated firmware is available for EC25-EUX LTE modem?
Current version:
Revision: EC25EUXGAR08A17M1G'
Getting empty AT response when using lpac even getting chip info:
LIBEUICC_DEBUG_APDU=true AT_DEVICE=/dev/ttyACM0 LPAC_APDU=at UIM_SLOT=2 ./lpac chip info
./lpac: /usr/local/lib/libcurl.so.4: no version information available (required by ./lpac)
[DEBUG] [APDU] [TX] CLA: 81, INS: E2, P1: 91, P2: 00, Lc: 06, Data: BF 3E 03 5C 01 5A
[DEBUG] [APDU] [RX] SW1: 90, SW2: 00, Data:
{"type":"lpa","payload":{"code":-1,"message":"es10c_get_eid","data":""}}
Same goes for QMI communication - Internal Error with no details.
Many thanks!
I have a quectel module that is not responding to the AT+QCFG=“usbnet” as expected. So I thought I would get the newest firmware and check again.
Michelle Vickrey with AssetWatch
Lafayette, IN (Columbus, OH)
Received as a test kit from rep Thomas Wied
[2024-12-27 12:04:25:522_R:] ATI
[2024-12-27 12:04:25:522_R:] Quectel
[2024-12-27 12:04:25:522_R:] BG95-M1
[2024-12-27 12:04:25:522_R:] Revision: BG95M1LAR02A04
FYI - I would like to run this module in mbim mode.
RM520N-CN
Revision: RM520NCNAAR05A02M4G
5966640@qq.com
I am using a RG255C-GL evaluation kit and I was wondering if I could get these firmware and software items from you:
Latest firmware for the RG255C-GL
Linux code for QLog
Linux code for QFirehose
Here is my information:
Company: Rocky Mountain Embedded Design Inc.
Calgary, Alberta, Canada
ATI: RG255CGLABR01A04M4G
would need the latest firmware.
Current version is: RM520NGLAAR03A03M4G_01.201.01.201
Please send me a DM.
Best regards
  1. Access Quectel’s Official Resources
    Customer Support Portal:
Visit Quectel’s Support Portal and log in. If you don’t have an account, register using your business email (Quectel typically requires verification for access).
Navigate to the Download Center and search for your specific module (e.g., EC25, BG95, RG501Q). Firmware files are often listed under “Software” or “Downloads.”
NDA or Partnership: Some firmware versions require a Non-Disclosure Agreement (NDA) or partnership with Quectel. Contact their sales team if necessary.
  1. Contact Quectel Support
    Submit a request via the support portal or email support@quectel.com. Include:
Your module’s exact model (e.g., EG915N-EU).
Firmware version needed (check existing module info via AT commands like AT+QGMR).
Proof of purchase or partnership if required.
  1. Distributors or Resellers
    If you purchased the module through a distributor (e.g., Digi-Key, Mouser), they may provide firmware. Reach out to their technical support with your order details.
  2. Firmware Update Tools
    Use Quectel’s official tools like QFlash or QUpgrade to flash firmware. These tools may require login credentials tied to your Quectel account.
  3. Caution
    Avoid third-party sources (e.g., forums, GitHub) for firmware, as they may contain malware or cause compatibility issues.
Ensure firmware matches your module’s hardware version (e.g., EC21V02 vs. EC21V03).
  1. Developer Community
    Join Quectel’s Forum for peer advice. Some users share guidance on firmware recovery or updates.
By following these steps, you can securely obtain authentic firmware while adhering to Quectel’s policies.
Please provide the IMEI1 number and the e-mail address,
thank you
BG95-M4
Revision: BG95M4LAR02A02
nils.hoffmann@smail.inf.h-brs.de
No Company
Germany, Sankt Augustin
Got the Modem gifted
I need a Firmware-Version that supports the “AT+QCELLSCAN=”-Command.
Thanks a lot.
i am trying to update to the latest rev for my rm520n-gl
bought from EMAX on aliexpress
RM520NGLAAR03A03M4G
jgsieve@gmail.com
thanks
Kind of the same boat. Need the windows Drivers for the RM520NGL and the original shipping firmware. Have one with 03A03M4G and it does not work the same.
im currently using Quectel_Ltd ,Quectel_CC660D-LS ,Revision: CC660DLSAAR01A03. any idea how can i get the latest firmware?
hi @venice
UDP downlink should work on CC660DLSAAR01A03
CC660DLSAAR01A03_01.002.01.002 is the latest Firmware.
Currently , can you please share if there’s any issue being faced at your end.
hi, but i couldnt receive any URCs for downlink and i tried to turn on either buffer/direct push mode it didnt work too it shows error
