@Bean.Wang-Q I am still waiting for the NTN-compatible firmware for BG770-A. Thanks in advance!
I have never known that the BG770 support the NTN.
Hi @Bean.Wang-Q,
Can you please send me qmi_wwan_q.c driver applicable for EG25-G.
Если можно тоже перешлите этот файл.
I’m trying to follow the guide:
quectel_umts_lte_5g_linux_usb_driver_user_guide_v3-2.pdf
I have an error when compiling my kernel on the GobiNet and qmi_wwan_q modules. I have a linux kernel version 6.12 that I cloned on GitHub - raspberrypi/linux: Kernel source tree for Raspberry Pi-provided kernel builds. Issues unrelated to the linux kernel should be posted on the community forum at https://forums.raspberrypi.com/
I found the drivers in: download-zone and more precisely in the zip: quectel_lte5g_linux_usb_driver_v1-0-2
Do you have a more recent version of the qmi_wwan_q and/or GobiNet drivers?
If not, which Kernel versions are compatible with the latest versions?
Best regards,
Augustin
It depends on which Quectel module you are using.
For some module the kernel 6.12 support by default.
I have a RG255C-GL module.
Ref : RG255CGLABR01A04M4G_A0.004.A0.004
Before I have follow the guide: I connect my modem, no driver is automatically displayed.
Since I followed the guide (quectel_umts_lte_5g_linux_usb_driver_user_guide_v3-2.pdf), I only have optional drivers mounted when I should have a qmi_wwan or a gobinet but I can’t have qmi_wwan_q and/or GobiNet drivers because I have an error when compiling my kernel on GobiNet and qmi_wwan_q modules.
Best regards,
Augustin
I am working with quectel-CM and i would like to establish multi-APN connection (RM520N-GL with Rpi).
Could I have the qmi_wwan_q driver along with some instructions on how to enable it and use it with quectel-CM?
And also if it doesn’t work for me how can i change it back to qmi_wwan that i am currently using?
Can you send me the latest files of qmi_wwan_q and the other tools? thx.
Please check the msg. I’ve sent it.
Hello @Bean.Wang-Q ,
I am working with the RM530N-GL module, and needed the qmi_wwan_q.c file. Could you please send it to me.
Thank you.
I have a RM502Q-AE module with f/w version RM502QAEAAR11A04M4G. I’m using a raspberry Pi with kernel 6.12.34+rpt-rpi-v8.
Can you send me the compatible qmi_wwan_q.c file and accompanying instructions.
Alease please confirm if the f/w itself need to be upgraded.
I am working with the RG255C-GL module, and needed the qmi_wwan_q.c file and last version of Quectel-CM. Could you please send it to me.
Thank you.
Quectel_Linux_Android_QMI_WWAN_Driver_V1.2.9 have been sent.
Can you also send me the most recent version, please? I get compiler errors with version 1.2.1 on Ubuntu 24.04.3. Thanks!
@Bean.Wang-Q Can you also send me the most recent version, please? I get compiler errors with version 1.2.1 on Ubuntu 24.04.3. Thanks!
Please check the Quectel_Linux_Android_QMI_WWAN_Driver_V1.2.9.zip
