Hello, in quectel_lte_5g_linux_usb_driver_user_guide_v2.0.pdf it says that eQuectel provides the source file qmi_wwan_q.c, which can coexist with qmi_wwan.c
and only be used for Quectel’s modules.gd
Where can I get file qmi_wwan_q.c?
Ok, I will send it to you via email, and please use it refor to linux_usb_driver_user_guide_v2.0 file.
Hello Isaac,
I need this file too.
Could you send me it also?
Regards
@Juanma
Ok, I will send it to you via email, please check it.
Hi Isaac,
I’m also looking for the qmi_wwan_q.c file.
Jeff
Ok, I will send it to you via email, please check it. @jeffisaacs
Hi Isaac, I need this file too, I can’t find it anywhere. Thank you!
@adrianboimvaser Ok, I will send it to you via email, please check it.
Hi Isaac,
Can you please send it to my email too?
Thanks.
Thank you…have received, but seems that this the same as the one provided by sixfab, version 1.2.1.
I have some problem integrating RM502Q with Rasperry Pi 4 + Raspi OS 64 Bit with 5.15.32 kernel.
Do you any complete guide on how to do this?
qmi_wwan_q driver already installed (confirmed by using lsusb -t and qmi_wwan_q driver exist), but when starting Connect Manager, unable to get dhcp ip address.
Thanks.
Hi, do you think you can send the file too?
qmi_wwan_q driver file?
Finally succeeded installing the RM502Q and RM500Q 5G module in raspberry.
Works on Raspberry Pi Buster 32-Bit with 5.10.103 kernel.
Not work on Raspberry Pi OS Bullseye with 5.15 kernel.
Thanks.
Hi Isaac,
Thanks.
I need the file as well to enable QMI
Hi Isaac,
Can you please send qmi_waan_q.c driver to me?
Thanks a lot
Hi Isaac,
Can you please send me qmi_wwan_q.c driver applicable for RM505Q-AE.
Thanks in advance
Hii Isaac I also want qmi_wwan_q.c. Will you please send it to me also?
Hi, I using openwrt and the linux version is 4.9.198. Can you send me the qmi_wwan_q.c for EC25. thanks.
