Firmware RM500Q-AE
what is the latest firmware for RM500Q-AE
AT+QGMR
RM500QAEAAR13A01M4G_01.001.01.001
I will send you the RM500QAEAAR13A03M4G_01.202.01.202 please check it.
RE: Firmware RM500Q-AE - Quectel Forums
May I get the Windows 10 driver as well?
Which file from the archive do i have to load using QFlash?
You can select any file in the firehose folder.
Hello @Bean.Wang-Q,
I also would like to have the latest firmware for RM500Q-AE.
I need to update in a Linux environment, if there is some specific documentation about how to do it would be nice as well.
AT+QGMR
RM500QAEAAR13A03M4G_01.200.01.200
Could you please send me the lastest firmwares for this module?
thank you very much, please send it to my email.
www.1156151899@outlook.com
Current version:
RG500Q-EA
Revision: RM500QAEAAR11A02M4G
AT+QGMR
RM500QAEAAR11A02M4G_01.001.01.001
Request the latest firmware for R13 and R11,thank you!
Best Wish
Dear @Flavio1
I have sent to your eamil, please check.
Dear @whale
Thank you very much @silvia.
Czy mógłbyś przesłać mi najnowsze oprogramowanie układowe dla tego modułu?
Dziękuję bardzo, proszę o przesłanie go na mój adres e-mail.
arni2003@op.pl
Aktualna wersja:
RG500Q-EA
Wersja: RM500QAEAAR11A02M4G
AT+QGMR
Poproś o najnowszy firmware dla R13 dziękuję!
Najlepsze życzenia
Dear @arni
Thank you, I received it, can you send me the latest firmware for RM502Q-GL
Dear @arni
Hello!
Could I please get the latest firmware for RM500Q-AE?
I’m on RM500QAEAAR11A02M4G currently.
strauchelnde@gmail.com
Thanks a lot!
Hi,@John_Smith2
I have sent to you via email,pls check
Thank you so much!
Can I please also kindly ask for the latest R13 version?
Thank you
Hi,@John_Smith2
It is not recommended to upgrade across baselines, as there will be a high risk of causing module abnormalities.
Hello, thank you so much for your clarification about the baselines. I was able to flash it with R11A03 version.
I wasn’t cautious enough though and blocked myself from using usb mode by sending AT+QCFG=“data_interface”,0,0. Tried to flash it again to reset the paremeter, the update was a success, but I still can’t send any AT commands. Is there a chance you have a version of firmware that resets data_interface parameter?
Thank you
Hi,@John_Smith2
Regarding this issue, perhaps you could create a new topic, describe it and provide detailed information about the problem. Our relevant technicians will help you.
pactrasebang@gmail.com
Current version:
RM500Q-AE
Revision: RM500QAEAAR13A03M4G
RM500Q-AE
Best Wish
