I can get the latest firmware, AT command and CA combos pdf for RM521F-GLEA? Current FW. RM521FGLEAR05A02M4G
Thank you.
Thank you.
Dear @JT_JT
The latest firmware is RM521FGLEAR05A02M4G_01.200.01.200, please check if it is same with yours. Please use AT+QGMR to query.
Other two documents, I have sent them to you via Message, please check.
Thank you. I have the current fw as of date.
can you send to me taht 2 Documents
Dear @Basim
Hello, can you also send me the two documents as well?
Is RM521FGLEAR05A02M4G_01.200.01.200 still the most current firmware?
Thanks!
Please can you send me the At command for RM521F-GL
My email : 331340@stu.rcyci.edu.sa
Dear @comconcepts
Sorry for the late.
I have sent the two documents to you via Message, please check.
RM521FGLEAR05A02M4G_01.200.01.200 is the latest one.
Dear @Majid_Alzahrani
I have sent it to you via Message, please check.
Hello Silvia,
Can I get the firmware. i need to reload FW: RM521FGLEAR05A02M4G?
Thank you!
I need to reload my firmware RM521FGLEAR05A02M4G. Please send it to me. Also send AT command document.
Please email me the latest firmware/driver for the Windows 11/10/ firmware upgrade tool for RM521F-GL module.
Email: sarkis.naj@gmail.com
Can someone send me the latest firmware as well?
Dear @Sarkis @JT_JT @jir591 @DoctaThompson
RM521FGLEAR05A02M4G_01.200.01.200 is the latest firmware, please check your current firmware.
If not the latest, please contact with your provider firstly, they have access to get the latest firmware and tools.
@silvia unfortunately my provider doesn’t have the latest firmware. If you don’t mind please provide it. Thank you.
Yes I agree, I contacted the provider and they don’t have the firmware.
Please send it to us
Yes. My supplier is not providing the firmware. You sent me the firmware for rm520n before. Can you please provide firmware for rm521f-glea?
Update: i no longer need the firmware.
Thank you.
Hi dear @silvia Can you please send me the Carrier Aggregation combo supported by the RM521F-QL module? And the AT commands manual for it? Thank you so much!
Dear @Sarkis @jir591 @JT_JT
Please check your current firmware whether it is RM521FGLEAR05A02M4G_01.200.01.200, it is the latest one.
Dear @Semsem
The two doeuments under process, I can’t share them to you now. Please share which combo and AT commands you want, I just can share the screenshoot to you.
