Hello please can i have the latest firmware update for my EM160R-GL? Now i have the 07 fw version. i need it Thanks
Can I use the ATI command to query the current specific software version number.
Thanks.
Hello the fw version is EM160RGLAUR02A07M4G
Thanks for your answer
I upload the latest firmware package to Baidu Cloud, and then you can get it on Baidu Cloud.
link:https://pan.baidu.com/s/1iImh-KEdemg0FSP9vHPmQA
Extraction code:jrrn
Quectel_EM160R-GL-AU_Firmware_Release_Notes_V0208_01.001.01.001.pdf (859.0 KB)
It would seem that there is a new firmware updated and that solves the bug servingcell, where you can find an original copy?
The technical support service does not provide it to me because I am a private person.
Здравствуйте а где можно скачать последние обновления для модулей EM160R и EP06 ?
Please provide your current version of EM120 and EP06, because EM120 and EP06 have different models,thanks.
Здравствуйте на моем EM160R-GL стоит прошивка EM160RGLAUR02A06M4G .
Про ЕР06 сейчас не могу точно сказать . Он находится на работе. Туда я в ближайшие несколько дней к сожалению не попаду. Поэтому если не сложно пришлите ссылку на последние прошивки этих модемов.
Quectel why don’t you make em160 modem updates public (every time you have to beg for the latest version).
What is the latest firmware version for em160 and where can I find it?
Where can I find the software QFirehose 1.4.9 or higher if it exists to update the modem?
The last one I remember is the EM160RGLAUR02A10M4G_01.001.01.001 which if I’m not mistaken I had seen it towards the end of December 2022 then I don’t know if others have come out in the meantime.
I request for latest em160rgl firmware. Pls send roddel007@gmail.com. thank you
I reallly need new firmware, my last version is EM160RGLAUR02A09M4G.
link is dead, please re-upload
Hello, I also need the latest firmware for EM160R-GL please.
Thanks!
OK, thank-you! Much apppreciated.
The last version I saw was EM160RGLAUR02A10M4G
With this firmware EM160RGLAUR02A10M4G sometimes I have Ite1 mbim: error: wdm send failed: 19 in my mikrotik 7.11.2 os version. Any updates or i need to use old fw?
My experience using version 10 is im getting bad carrier aggregation. Only 2 bands. So i switched back to 09.
Also qmi is stable than mbim
Hi All,
@Kerr.Yang-Q Please send me link to the latest FW. (rafalmail@int.pl)
