I have an EM12GPA-512-MSFT3 originally in a Surface Pro 7+. I am using this currently in an M.2 usb adapter.
Please can you provide me with the “Quectel_LTE&5G_USB_Driver_For_MSFT”. The standard USB drivers do not give me access to the COM ports on this device.
I have flashed EM12GPAR01A09M4G_MSFT to the device using QDLoader. If there is a more recent firmware update to the MSFT version please can you provide that too.
The hardware ID for this device is “USB\VID_2C7C&PID_0307”. I can see this device has been discussed in the support forum in the past.
I have received the links and will try them tonight when I am home.
Will I also need “Quectel_LTE&5G_Windows_USB_Driver_For_MSFT_V1.0.7” mentioned in the firmware release notes? Please could I also request access to this file just for completeness and to help with additional troubleshooting.
Just checked the files. I was able to flash the firmware using QDloader mode - thank you. The included driver package did not work for my version of card though.
However, I am still unable to access any COM ports. Please could you provide me with the “ Quectel_LTE&5G_Windows_USB_Driver_For_MSFT” to see if this helps.
I appreciate this is a vendor specific card which has caused issues in the forum before, but would like to try.
No, there are no unknown devices in device manager. Thinking this was a Windows 11 issue, I have tried this on a Windows 10 machine with similar results.
This forum discussion appears to have the same version of the EM12G that I have.
I can see two different HID/PID devices:
USB\VID_2C7C&PID_0307&MI_00
USB\VID_2C7C&PID_0307&MI_02
I am unable to see any way to send AT commands. The forum post I linked previously suggested there should be another ID:
USB\VID_2C7C&PID_0307&MI_04
None of the Quectel driver packages I have tried have installed have been compatible with this PID. The only set of drivers that I have been able to get to work are the ones extracted from the Microsoft Surface Pro 7+ update package.
There is also a possibility that the M.2 USB adapter I am using is limiting by ability to access the device fully, but I do not have another one to try at the moment.
The card does not appear to have any COM ports available, and I have only been able to get a COM port by putting the device into QLoader mode by shorting the pins (as detailed in the previously linked forum post).
So, given that others in the forum with this variant of the EM12 have access to the serial interface, I suppose the next question would be whether there is any way to enable the serial interface on this specific module? It does not seem to matter which OS I use, I am unable to see a serial interface.
My guess is it’s locked down in some way after being in the Surface Pro. Regrettably, I no longer have access to that device to put it back in to test and see if there was some more I could do with it.
For the time being, the card does work in MBIM mode, but it would be useful to have full access to the cards interfaces.
